Question about Dryers
Dryer not getting hot
Igniter light sometimes but flame does not
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
Dryer was working up until last load today now not hot...did notice a pretty full lint filter so i emptied that...but still not hot
Posted on Oct 11, 2009
No Gas Flame
Very common problem. The solenoids when cold will sometime work once then get hot and fail. Replace the coils. I made a short video which shows how it works and how to replace the coils on a similar dryer with the same type of solenoids:
Aug 29, 2013 | Maytag Neptune MDG5500AW Gas Dryer
The gas dryer is not getting hot enough to dry clothes have to run it double the time to get clothes dry-exhaust not blocked-igniter is working-there is a flame-checked dryer heat setting manual knob with...
You might want to replace the thermacouplar. Sometimes when they are going out , all will appear to be alright but as you stated it takes a long time for the flame to come back on. This sounds to me like the thermacouplar is going out.
Dec 08, 2009 | Amana ALG331RAW Gas Dryer
GE DRYER DDG7288- Not getting hot. No flame. Is there normally pilot flame? How is ignition reached?
There is not a pilot flame. These dryers use a glow bar igniter. As they heat up, there resistance to electricity changes, which in turn causes the amperage use to change. When the amperage use reaches a certain level, the gas valve opens and the gas ignites when it contacts the orange hot igniter. (30 to 90 seconds or so) Then, if the flame sensor detects a flame, you are good to go. If not, gas is shut down. Make sure you have a good strong flow of air out the outside vent pipe. If so, the igniter is the most likely culprit. It is located at the begining of the cumbustion chamber, about six inches or so from the gas valve.
Oct 26, 2009 | GE Dryers
Dryer spins but dosen't get hot
Since you indicated that it had an igniter I assume you have a natural gas or propane model. I had some trouble with a Hotpoint dryer and replaced the igniter. That didn't solve the problem. I then decided to just change the gas solenoid and the flame sensor at the same time and it worked fine again. I got them both cheap from Ebay from the same seller.
The flame sensor tells the machine if the ingiter was able to light the gas burner. If it doesn't sense the heat it will turn off the gas solenoid so your house doesn't fill with gas. The gas solenoid is an electrical valve that lets the gas flow into the burner. You should be able to hear the gas solenoid click when it opens and then your igniter will glow and start the flame. If it shuts itself off within a minute of that then I would suggest the flame sensor as a starting point. If it never clicks then I would start with the solenoid.
Good Luck and post back here if you solve it for the next person with your trouble.
-- Kevin
Sep 27, 2009 | Maytag Dryers
Our whirpoolgas dryer is not hot.We changed the
when you start you dryer and it got hot little bit and then won't got hot again? if yes then you may need new flame sensor..or if you can see your dryer igniter turn on your dryer and watch..you heard click sound then igniter will glow then one more click sound and should see flame..ok watch for 10 min..if after click sound igniter glow and other click flame will not apper then you need new gas valve..good luck..let me know it help or not...thanks..
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Gas dryer wont get hot
Then your ignitor needs to be replaced. You should be able to pull the plug in the front panel and see the ignitor turn red. if its not red replace it and that will fix ya up!
Nov 20, 2008 | Kenmore 73952 Gas Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Dryers Logo
3,695 people viewed this question
Top Dryers Experts
