Question about E-Flite 1s 3.7v Li-po Battery Charger Mcx Eflc1003
The red light is always on, and it doesn't seem to be charging. Its almost brand new.
Same thing started happening to me. The red charging light was initially going out but then after a few days use started staying on. I assumed that the battery was damaged and bought 3 new batteries but the red light is still staying on when I charge the new batteries.
I suspect that the mains charger I was using (same voltage but not the recommended charger) has perhaps damaged a component inside the EFLC1003 unit which is now not letting the power through to charge the battery.
Posted on Dec 30, 2010
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
My msi u100 starts up but then the battery light goes red and shuts down how can i fix it
HI Cws666, try to charge your computer for a full 3 - 5 hours without interruptingit, than try again.
If that doesn't work, try buying a new battery.
If that doesn't work send it to computer's brand labs.
Jun 08, 2011 | MSI Wind U100-280US Netbook
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
New Camera Does Not Charge
A red flashing light does NOT mean it charging. THat means you have a defective battery. Call tech support and tell them that you have a defective battery and they may be able to get a replacement for you.
Jun 08, 2007 | Casio Exilim EX-S600 Digital Camera
E-Flite 1s 3.7v Li-po Battery Charger Mcx Eflc1003 Logo
490 people viewed this question
Top E-Flite Toys Experts
ray gallant
Are you an E-Flite Toy Expert? Answer questions, earn points and help others
