Question about Nokia Cell Phones
My memory card is not detected by the computer when i connect it using crd reader this shows that please insert disk
Are you kidding mee...by saying that memory card is not showing i mean it has been corrupted...its not even showing neither on phone nor on pc....how can i get my data back..?
Posted on Nov 06, 2012
  • 384 Answers
You can have the solution by doing the followings --
install pc suite software for your phone .
then connect your phone through data cable .
then you can access your memory card in your pc .
Posted on Dec 30, 2010
Please solve my problum how to format nokia 6233 phone memory with computer
insertyour usb cable to your system and connect to your phone after the connection between your system and your phone when the system recognises your phone look the computer names your memory card and your phone memory either removable disks so dont open your memory card on the system just right click and go to format you can format using the quick forrmat or the other
but if you are using a card reader just insert your card memory card into your card reader and insert your card reader to the system and right click then in the options that would be displayed click on format then you can format your memory card that way
Jan 22, 2011 | Nokia 6233 Cellular Phone
Tip
How to repair memory card
  1. Download and install a data recovery program. The first thing you want to do when you encounter a memory card error is to attempt to recover important files. There are a number of programs available to accomplish this. Photo Rec is a powerful, free option for most operating systems, but lacks a graphical user interface, which can be intimidating for less advanced users. Find the data recovery program you are most comfortable with in terms of price and features.
    Insert the memory card into your computer's memory card reader. Use a USB card reader or connect your device to your computer via USB if your computer does not have a card reader.
    • Some devices require that you enable disk use via USB through its settings before your computer will recognize it.
  3. 3
    Run your data recovery program. Follow the procedure to recover files for your data recovery program and recover what you can from your damaged memory card.
  • 2
    Go to Computer. Open the Start menu and click Computer. Type Computer into the search box if you cannot find it.
    • In Windows 8, Computer is called This PC, and can be found by searching forComputer from the Start screen.
  • 3
    Find your memory card. Your memory card will be listed under Devices with Removable Storage (Devices and drives in Windows 8). It should be named something like "Removable Disk (M:)". Make note of the drive letter, as it will be needed later.
    • If you cannot tell which disk is your memory card, remove your card with this window open and note the drive that disappears. Remember to reinsert you card before continuing.
  • 4
    Open Command Prompt. From your desktop, press ? Win+R to open the Run dialog. Enter cmd and click OK.
  • 5
    Run Check Disk fix and recover. On Command Prompt, type chkdsk m: /r, where m: is the drive letter of your memory card, then press ? Enter to begin.
    • Depending on the errors found during this process, Check Disk may ask for your input in regards to what action it can take. When this occurs, answer "Yes" and press enter to continue.
    Part 3 of 3: Repairing a Memory Card on Mac
    1. 1
    2. 2
      Run Disk Utility on your Mac. Disk Utility is a Mac operating system utility that can perform disk-related tasks. Select Go from your Finder menu and select Utilities or press ? Shift+? Command+U from the Finder to open your Utilities folder. Open Disk Utility from your Utilities folder.
    3. 3
      Select your memory card. Find your memory card on the list of connected drives. If you do not know which drive is your memory card, remove it and reinsert it to determine which drive it is.
    4. 4
      Repair your memory card. In the First Aid tab, check the "Show details" box, then click Repair Disk. If Disk Utility reports any errors, repeat the repair process until it finishes and reports "The volume appears to be OK".
    on Aug 24, 2015 | Philips SAC2530 - CD/DVD repair kit...
    When i insert my memeory card reader it is detected but showing a message 'please insert a disk into drive g'.....how to rectify this problem....
    this is the problam with your card reader's socket just clean.........or check there should no parrword installed on your chip it can be also the problam plese insert that chip in mobile delete password then use it...................
    Nov 13, 2010 | Electronics - Others
    Everytime i try to download music to my memory
    try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
    in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
    Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
    Memory not readable by PSP or Computer. HelP!
    Dear Friend,
    you have to check the Following
    • Make Sure Your MMC is NOT PASSWORD PROTECTED
    • Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
    • Properly Inserted MMC to READER
    • Change USB port if Still Not Detecting
    • Try another MMC to Reader
    • Reinsert your MMC
    • Reboot your PC
    Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
    YOu are done...Solved.....
    IS this HelpED you ... Do RaTe mE...
    you can Feel Free contact me... Thanks for Using FixYa
    Apr 04, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
    How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
    You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
    All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
    I'm sure 100 works!
    Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
    Have a olympus sp-56 ouz digital camera and I can't figure out how to delete videos taken on the camera. I've already transfered them to my computer and I've deleted all images, but it won't delete the...
    Hello, The videos will not be in the same folder where your pictures are. Follow these steps. 1.First, connect your digital camera to your computer. You can do this in two different ways: a.Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. The first time you connect your camera to your computer, the New Hardware Wizard will help you install the software needed to copy pictures and video from your camera. You may need to insert the CD-ROM that was included with your camera into your computer's CD drive or download software from your camera manufacturer's Web site. b.Use memory card reader. A memory card reader is a piece of hardware that plugs into your computer. When you're ready to download video, you can remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Picture of a computer with a memory card Tip: It's usually faster to use a memory card reader to copy your pictures or video than to connect your camera to your computer with a cable. If you don't own a memory card reader, you might want to consider purchasing one. They are inexpensive and will save you time. 2.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection to your memory card and ask what to do with your videos. Click Open folder to view files, and then click OK. Click Open folder to view files, and then click OK 3.Windows Explorer opens, showing your memory card. Your videos are contained within one of the subfolders of the memory card. Double-click each folder to locate your videos. 4.Once located. copy them to your computer and then select all and delete. Please rate my solution. Good luck, Jegan
    Jun 04, 2009 | Olympus Cameras
    Memory card
    First let me know whether the memory card is detected by pc using PC suit.. If it does then ur adapter where ur inserting ur card is not working properly . get a new adapter and insert via memory card or 'direct' , it will work
    Feb 10, 2009 | Sony Ericsson K550i Cellular Phone
    MMC card support in compaq
    Well basically what you do is
    1.) connect your memory card reader
    2.) install the necessary drivers
    3.) insert the memory card and it should show up as a removable disk in my computer similar to that of a pen)flash) drive
    If the card reader is built into the computer then simply ensure the necessary drivers are installed (right click computer and select properties, then click device manager , it will show up in the list, if it has a yellow maker then it has a problem if its a question mark then it aint installed) if you dont have the drivers get them from the manufactures web page. IF everything checks out ok then put in the memory card and it will show up as a removable disk in my computer..
    If you dont have a memory card reader or dont have the card reader built in then you will need to purchase one.
    Jun 29, 2008 | HP Compaq Presario V6000T Notebook
    Cell Phones Logo
    37 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
