Question about Sharp R-1502 Microwave Oven
Fuse blew on sharp 1000 watt microwave. Put in new fuse same thing happened. Read in book, if replace fuse you need to replace switch. How much is a switch, where is it located in microwave, is it hard to replace? Thanks. Ron gotgoji@verizon.net
hardrocko
  • 1476 Answers
SOURCE: Sharp microwave oven R345 M 900 watts
In most cases the displays are protected by a low value resistor which could have burned out. First someone needs to determine if the display is getting the proper voltage. If it is and still does not work you need a display. If it isn't getting any power follow the circuit back to the power supply and you'll probably find an open resistor or micro fuse (which looks like a resistor).
Posted on Jun 22, 2006
SOURCE: GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Posted on Feb 28, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Location of monitor switch for Sharp R-5A54B microwave
It's usually the one in the center, as opposed to the being near the top or bottom edge of the door.
The entire service manual is available for free download on the Sears parts site (page by page) at http://www3.sears.com/ (the 3 is correct)
Just look for the switch as ref # 1-7 on this diagram:
http://tinyurl.com/yqc9ol
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp R-420AC microwave blown fuse.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Jan 10, 2009
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Sharp Microwave Model #1482
now!the microwave is cheaper in market! if you call repairman! he will ask equal to new microwave rate price! better think is buy new microwave! check the fuse in microwave! then you buy the new one!
Jul 06, 2008 | Sharp R-1480 Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Blows internal fuses after replacing
Did you use correct fuse??? REMEMBER MICROWAVES CAN KILL EVEN WHEN UNPLUGGED
grandadfixer
Apr 30, 2008 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool microwave oven
The magnetron are short need to replace / look for the old or in junk shop magnetron same serial # and etc
Jan 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Microwave stopped working
Sounds like it blew the fuse, and when the fuse blows immediately upon hitting the START button, I'd say you have a shorted high voltage capacitor. But it may also be an open thermal cutout on or near the magnetron or just a fuse. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like JVM1860B01, not XL1800 or Spacemaker) here: http://tinyurl.com/gv383
May 05, 2007 | GE ZMC1095SB 800 Watts Convection /...
Sharp R-1502 Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
