Question about Sharp AR-5316 Advanced Digital Imager Copier
My copier dispaling H2 WICH problem?how to solved that?i need help
  • Sharp Expert
  • 316 Answers
Thermiter open ditection
Posted on Dec 30, 2010
Sharp A5518 - Error Code H2, copier not working
h2 - thermistor error
press
# - Interrupt - Clear - Interrupt
then
14
then
press start
Mar 25, 2015 | Sharp Office Equipment & Supplies
H2 code
Put on ur machine & go 2 ur display board & press the C button twice then ur display will go off then input figure 1 & 4 that is 14 then press the print button. if this fails then remove ur fuser unit & check d thermistor, clean any dirt b/w d fuser roller & the thermistor, u can test d thermistor by connecting the two terminal 2 ohms meter
Dec 04, 2013 | Sharp AR-5320 Black and White Copier
I HAVE SHARP AL-1216,I DONT KNOW HOW TO REMOVE H2 ERROR CODE
H2 deals with the fixing unit.... You need to fix the problem before it can be rest. It may just be the fuser lamp is blown. You have to take it out and if it looks like a candy cane that is the problem. Good Luck
Jan 15, 2013 | Office Equipment & Supplies
H2 error message
H2 Error
Content
Thermistor open detection
Detai
l Fusing thermistor open
Cause
Thermistor defect MCU PWB defect
Fusing section connector contact failure
Power supply failure Fusing unit not installed
Check andremedy
Check the harness and the connector of the thermistor and
the MCU. Clear the self diag display with SIM 14.
Aug 29, 2012 | Sharp AR-5516s
Toshiba e-studio 161 error code H2?What reset problems?
does not solve these problems H2? substituted for the other thermistors, but still nothing same error ... The whole problem of the scheme not remove the plug from the power supply and printer cable recorded the error, which now does not solve ... help ??????
Jan 12, 2010 | Toshiba e-Studio 161 Copier Copier
Error Code H2
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Jul 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
2h flashing on screen,won't print
heat roller problem , enter # ,interupt, c , interupt machine goes off and enter 14 then press print buttom. this might clear ur problem. if it repeat same h2 code. need to change thermister and enter above code 14 again
Dec 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Dec 31, 2007 | Sharp AR-5320 Black and White Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
