Question about Garden
Lawn hornet fires up from 2 or 3 pulls, runs for 2 seconds then needs a minute or 2 before it will do the same thing. fuel is 40:1....DMac
    Novelist:
  • 144 Answers
Before doing anything check the carb fasteners to make sure they are properly torqued as air could be leaking in making the engine not run right, also check the air and gas filters, fuel lines and anything obvious also as a possibility they might be the problem. If anything obvious like that does not work, this could be a carburator ajust problem. Many of the carbs on grass trimmers in the past few years do not have adjustment needles, everything is ported inside the carb. So without knowing anything about your machine and if you have adjust needles this is the basic procedure for adjusting. The 2 needles might completily be out of adjustment, so turn them in ( clockwise) until lightly seated so the seat is not damaged, now turn the 2 needles counter clockwise 1 turn. This is the basic adjust for most carbs to start and run, now make the adjustments. Turn the low speed needle about 1/8 of a turn at a time counterclockwise to let more gas in and try that up to 1 turn (always remember the start position before any adjustment is made). If that does not work return to start position. Now try the high speed needle with the same procedure. If that does not not work, try adjusting both at the same time. If nothing works you probably need a carb overhaul. Maybe only a cleaning or a carb kit might be needed. I hope this helps you out a little. Best regards and good luck.
Posted on Dec 30, 2010
Have Honda HRB215 mower. Fired right up first use this season and operated fine. Week later fires first pull then dies after couple seconds. Drained gas and replaced, checked fuel filter, gas lines etc....
Have you checked the spark plug? Mine was doing the same thing. Not staying cranked and sputtering while running. I changed the plug and it runs like new. Hope this helps
Jul 11, 2012 | Garden
Starting mac 3227 trimmer
As you have done most things, i would suggest you have a massive air leak, either through the cylinder or crankcase gasket, or through the crank seal, i think its time to pull the whole engine down and replace these items.
May 29, 2012 | Garden
After running 2 minutes tractor cuts off
The fuel not going to carb.
Mar 03, 2012 | Ford Garden
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Honda em2500 starts, runs 1 minute, quits and will not restart
If the oil level is low it will do this, but I also know this to happen when the oil is very cold (thick) an won't fow back own o the crankcase where the oil sensor is. The slow return results in a low oil level. My solution is to start it, when it dies wait a couple of minutes and retry... after a few starts, the oil will warm up, thus flowing back down faster and it then will run. Another option is to use a thinner oil ie;5-30w.
Apr 19, 2009 | Electrical Supplies
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi Weed Hornet RWH1100 Mk 11 - carby diagram required.
had similar problems with my mum's 77. she was going to throw it out so i adopted it. turns out i just needed to adjust the injection screw. couldn't tell u where it is as i did it five years ago but armed with the knowledge that carbys have them and a bit of dissassembly i was able to fix it pretty easily. still runnin great now till the starter mechanism stuck. time to pull it apart again, hence my visit to this forum....
Mar 12, 2009 | Ryobi Garden
Fuel ratio for Ryobi lawn hornet mk 2
25 to 1 = 200ml of 2st oil to 5 lt ulp
OR I use 150 ml "stihl" 2st oil to 5 litre of ulp Less smoke and better oil.
Jan 12, 2009 | Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
