Question about Whirlpool Dryers
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
  • cmaino Jul 07, 2008
    it has a flame ignitor, how do I get to these parts for this unit. tHE FRONT DOES NOT HAVE A KICK PLATE
    Scholar:
  • 148 Answers
Mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Posted on Jul 07, 2008
  • derek martin Jul 07, 2008
    its not the flame sensor cause it has no flame,if it had a flame then it stop and tried to relight again it would be a flame sensor
  • 2,326 Answers
I would suggest to read the info by clicking here to find out what could be wrong with your appliance.
  • 6,487 Answers
What type of gas ignition does your dryer have? I believe some have "spark" ignitors and some are equipped with with "glow" ignitors. If your dryer is equipped with a spark ignitor you should be able to hear a ticking sound when you first start the dryer. If your dryer is equipped with a glow ignitor you will be able to see it glowing white hot (usually by removing a panel from the bottom front of the dryer). If the ignitor is malfunctioning, the dryer will not heat...all it will be doing is blowing cold air. A bad ignitor is a common problem.
If the ignitor is working there could be a problem with the heat sensor. The heat sensor is a device that is heated by the gas flame and sends a signal letting the dryer know it is okay to keep the main gas valve open (just like a thermocouple on a hot water heater sensing a pilot light).
Hope that helps.....
Whirlpool dryer ignighter replaced still wont heat
The gas dryer assembly consists of a sensor, a ignitor, and a pair of solenoids. The flame sensor must have continuity when cold to fire up the ignitor. The ignitor must be hot and out of the circuit so that power can open them coils. So how do they do it? The control themostat is mounted very near the blower and filter housing. As the air passes by it on the way outside it judges air temp. When the temp drops below 105f the control powers up the gas assembly. The sensor, the ignitor, and the coils are all energized. The ignitor is wired cleverly so that while it is being powered by the flame sensor it takes up most of the energy required to open the coils. Once it gets heated up to ignition temp the bimetal inside the black box (sensor) shuts down power to the ignitor. It is so hot it is now a therm sensor itself. Full power goes to them coils and they can now open the valve. As the flame is ignited the 3rd wire on the holding coil is kept open by the heat from the ignitor which becomes a themo generator. Fascinating isn't it? My home movie:
More enlightenment
Dec 05, 2012 | Whirlpool LGR5636L Gas Dryer
Whirlpool dryer will not ignite.JET FLAME WILL NOT GO ON.
if the ignitor is lighting up, or if you have a actual flame pilot light, depending on the machine, if you have a pilot light, check the thermocouple that the flame from the pilot is supposed to heat , but thats on very very old machines , if you have a glow plug , ( a heat source that comes on electrically and glows , then you need to check the 2 coils that are on the gas valve, they have gone bad
Jul 13, 2011 | Whirlpool Dryers
No heat coming from dryer
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 30, 2009 | Whirlpool Dryers
Why wont my dryer heat up
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Nov 26, 2009 | Whirlpool LGB6300 Gas Dryer
The dryer does not heat
Nov 19, 2009 | Whirlpool Dryers
I have a whirlpool dryer.... the blower works fine but will not heat up any suggestions
Nov 12, 2009 | LG DLE0332 Gas Dryer
My whirlpool dryer wont heat up
Oct 27, 2009 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Whirlpool LGR7646EQ0 turns no heat
the dryer has no pilot light, haven't had them in years. It operates off a hot surface ignitor.I would check to see if you are getting power to the ignitor 115v. If you are the ignitor is bad. Sometimes you can see the ignitor cracked. Did it take long to dry the clothes before it quit? If so your vent may be clogged which will blow a thermal limit on the dryer and keep it from heating. hope this helps...
Nov 19, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
