Question about Maytag NFW7200TW Front Load Washer
Amana NFW7200tw is leaking. Broken grey piece of PLASTIC from the door fell on floor when we opened the door to remove laundry.
5 Suggested Answers
  • 1073 Answers
SOURCE: Kenmore washing machine 110.92580100
replace the direct drive coupling it is located between the transmission and the motor part number is 285753a if you need further help let me know
Posted on Apr 26, 2008
Jahn27
  • 1554 Answers
SOURCE: washer will not spin or
The motor coupler is broken and the black round rubber piece you found under the washer is the rubber grommet that connects the coupler parts. The six plastic teeth are the coupler prongs, 3 for each coupler part. Replace the motor coupler.
Disconnect power and release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Disconnect the motor harness then remove the screw securing the bottom clip holding the motor and remove the clip. Hold the motor from the bottom while loosening the screw securing the top clip holding the motor. Remove the clip then pull the motor out of the washer.
Remove the broken coupler parts from the transmission and the motor shaft then tap the new coupler parts in place or until the splines are even with the edge of the coupler.
Remove the motor mounting plate to remove the coupler part in the transmission side more easily.
Once the coupler parts are properly installed, put the rubber grommet into the coupler in the motor then line up the remaining slots on the grommet with the coupler prongs in the transmission and put them together.
Secure the motor with the clips and the clips with the screws then reconnect the motor wiring harness to the motor terminals and reinstall the pump in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Oct 12, 2010
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Posted on Dec 11, 2010
richroth
  • 9472 Answers
SOURCE: My Amana NFW7200TW front loader Washer door is
You need to replace the door. Here is a link to the part you will need.
Posted on Dec 24, 2010
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
Amana nfw7200tw will not run. all wash settings read 1 extra minute. Is this a code or something like that?
have you tried unplugging and resetting the computer, it seams hung in the last cycle, can you open the door and remove all inside, reset it again and try it, the washer sounds like it has water in it and needs to drain first,if it is full of water you have to drain it, by moving it and taken the drain hose off the pump,if that's the case i recommend flushing the inside with hot water and some bleach right through the front door or reservoir on top,after you get it emptied, the water sensor may be full of soap, by the way the soap your putting in this machine should only be about a 6th of a cup, I know it sound crazy but a half or a 3rd is to much, for the sensors, try this an get back to me,Matt
May 01, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Strange thing over night my refrigerator has lost the suction in the doors. I have to close the door and hold the door close, to keep it close
there is a plastic part that attaches to the lower hinge that helps keep the door closed. it is like a rocker that when the door is open the door rides up on the plastic rocker then as you close the door the door rides down on the hinge rocker and helps to force it closed. mine stopped closing on it's own then all of a sudden the black plastic piece broke and fell to the floor. I am ordering a new piece if I can find the part number.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
The inside door handle does not open the door. I can open it from the outside but not the inside.
I just fell into the same situation. My interior driver's door handle just does nothing all of a sudden. I went on the Mazda Forum website and came away with at least a temporary fix.
The lock switch can be used to open the door from the inside by pushing it the opposite way it's pushed when locking the door. In other words, the rear portion of the lock switch needs to be depressed and the front portion needs to be pulled away from the door. It may be difficult to do with the trim piece around the lock still on. The trim piece can be removed by pulling the small plastic cap away from the base (it's on a plastic hinge) off and unscrewing the holding screw underneath it. Pull the handle away from the door and the trim piece will come right off.
I'm using that as a temporary solution now until I get a new/used door assembly.
Hope that helps.
Sep 02, 2009 | 2001 Mazda Tribute
Dryer was working when I opened the door to see if clothes were dry then I went to use it agin and it would'nt work
probably broke little door switch in door look for a little plastic piece proably fell on floor
Jul 12, 2009 | Dryers
Amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Feb 25, 2009 | Amana Washing Machines
Door Latch does not open door
I threw caution to the winds and removed the outer panel of the appliance. The plastic latching handle practically fell out--it was broken. Called all local parts suppliers--none had any parts in stock for this dishwasher. Called the manufacturer, who had a part listed on his computer at a distant location. Ordered it, paid for it, and was assured the part would be received within 2 days. Incidentally, you can't order just a replacement latching handle. It is included as part of a component.
Sep 22, 2008 | Amana 24 in. ADB1200AW Built-In Dishwasher
Maytag NFW7200TW Front Load Washer Logo
157 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
