Question about Compaq Presario 1626 Cooling Fan Case Cooling Fan
Compaq presario sr2000 wont turn on. No fan, no whirling, no beeps. One very dim green light on back of computer. Where to start - power supply? Electric was shut down not by lighting but the whole apartment complex went out. has not started up since then.
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
gilheero
  • 207 Answers
SOURCE: Compaq Presario S6000nx pc wont start up
check the connection of your wires through your motherboard? try to reseat those connection( caution: you must have an assistance of any qualified personnel or technician because if you reconnect it in wrong position,this will result the motherboard to burn)
BE CAREFUL!!! but this will help..
Posted on Jan 24, 2008
  • 254 Answers
SOURCE: Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Posted on Jan 01, 2009
wahidmeer
  • 33 Answers
SOURCE: Compaq Evo D5 power light flashes red.
Check the power supply unit.
Posted on Aug 19, 2009
  • 1015 Answers
SOURCE: compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Posted on Sep 05, 2009
Compaq Presario S3190UK wont start and it just beeps
There could be a number of things, from a corrupted BIOS (easy to fix) to a failed motherboard (end of computer) and several in-between. This forum just isn't set up for this kind of in-depth help. I hang out at www.suggest-a-fix.com (free) computer help forum. Sign in and post in the Hardware and Media section, then me or someone else will be along to help out.
Apr 08, 2014 | Compaq Computers & Internet
Compaq presario S3190UK wont start, it beeps
That beep usually means a hardware problem. Try first unplugging every external hardware, like printer, keyboard, mouse, external hard drives, etc. Try powering on, if you get the same result DISCONNECT THE POWER CABLE, and try opening the computer and removing the RAM Memory modules one by one, try powering it on after removing each, if you removed all and still get the same beeps put them all back in and you may need to try the internal additional hardware such as PCI/PCIe cards (Non-integrated network card, non-integrated video cards, etc.). If all of this fails take it to a certified technician as you may have a main-board issue. DO NOT REMOVE OR ADD COMPONENTS WITHOUT FIRST UNPLUGGING THE POWER CORD.
I have a compaq presario SR2020NX 2005 and there been like around 3 years that I have not been using it, then I decided to turn it on ( started beeping) well I brought everything new ( power-supply...
Rita...Unplug the computer, take your BIOS battery out (make a note of which side is facing up!), wait 15 minutes, replace the battery (make sure it goes in the same way it came out, do not reverse polarity by accident) and reboot. Does that help? If you had this work done on your computer by a service, contact them with this problem. They should have tested the unit before sending back to you.
Aug 10, 2013 | Compaq Presario SR2000 Desktop PC series...
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
When I attempt to boot the unit, no signal is sent to the monitor or keyboard, nor does the green light next to the power button turn on. The amber light does not, either. The fan will run at high power...
I had the same problem with my computer and the Compaq-HP techs told me to pull the ram out and then put it back in. They called it reseating the ram.
This fixed the problem i had. Try this and good luck.
Feb 14, 2011 | Compaq Presario S4020WM PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
Wont power up green light on back is on but
Most likely a failure in the internal power supply of the tower. Replacements are around $50 if not under warranty.
Oct 09, 2009 | HP Compaq Presario SR2150NX PC Desktop
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Compaq Presario 1626 Cooling Fan Case Cooling Fan Logo
590 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
