Question about Dryers
Cycle selector loose...broken... - Dryers
  • Mark Freedman
    Mark Freedman Dec 30, 2010
    This is a common problem with some of the Sears/Whirlpool dryers. If you can get me
    the MODEL number of your dryer, I can refer you to where to get a replacement knob.
    Best, Mark
  • 42 Answers
Dryer Diagnosis & Repair Before we start with any diagnosis or any repair, we must give you an URGENT WARNING. Your dryer is hooked up to either a 240 volt(electric dryer) or a 120 volt(gas dryer) electric source. Either source can easily shock you and KILL you! Use extreme caution and make sure to unplug the appliance or remove the electrical power to the dryer! Another thing to keep in mind. More and more appliances, including dryers, are going to electronic controls with digital readouts. These types of appliances usually have the capability of giving you an error code. These error codes can then be looked up in either the owner's manual, tech sheet(somewhere on or in your appliance) or on-line. This error code can save you or the technician time in diagnosing the problem with the unit.
One other thing to remember before calling for dryer repair, is make sure the dryer is getting power. That it is plugged in and the breaker is fully on. We hate charging for a service call when the problem was a tripped breaker.
Dryer Won't Start
1st check to make sure your dryer is getting the proper voltage by using a voltage meter or multi-meter. Electric dryers should have 220-240 volts while Gas dryers will have 110-120 volts. You can either check the wall receptacle or at where the cord comes into the dryer. This should be always your 1st test to diagnose a problem. If you do not have the proper voltage, then your dryer will not start or possibly just not heat.
For example, on a electric dryer you have either a 3 wire or 4 wire plug coming into the dryer. No mater what, the 2 outside spades are your hot leads(the red wire & black wire), the other one or two spades are your neutral/ground or your neutral & ground separated. Take a voltage measurement across the black & red leads on the back of the dryer and you should get 220-240 volts. Measure either the black or red leads to the white or ground leads and you should get 110-120 volts.
cycle selector loose...broken... - j0320184.jpgNow back to the dryer itself, depending on the brand dryer, say a Whirlpool, the black wire runs both the motor and the heat element, and the red wire only runs the heat element. So, if your breaker to your electric dryer is only partially tripped(1 of 2 breakers) you could see your dryer either run with no heat, or it would not start at all. That is why it is so important to check your voltage before starting any other diagnosis.
Now unplug or remove the power to the dryer to check other causes. Your door switch could be open, not completing the circuit. This can be checked by a resitance/OHM test. Your Thermal Fuse could be open which is usually located on the blower or heat element housings. That again can be tested with an OHM tester. The Push-to-Start button may not be closing, again test with OHM tester. Your timer may not be sending the voltage out, this is a little more complicated test to do. You have to be able to read the wiring diagram and test for voltage coming out of the timer to the motor, use extreme caution on this test. The motor start switch or motor itself could be open, again read the wiring diagram and perform an OHM test on the correct wires with the unit unplugged. Lastly, check the obvious for any broken or loose wires and/or connections.
Dryer runs, but does not turn
This problem is usually pretty easy. If you here your dryer motor running and the drum is not turning, most of the time you need a new drum belt. Other causes could be a broken drum belt idler or pulley, a stripped pulley on the motor, or something jammed between the drum and dryer cabinet keeping ot from spinning.
Dryer runs, but timer does not move
Another fairly easy one. Most of the time, you have a stripped timer, especially if you are using it on the timed drying cycle. Other causes could be a thermostat problem in the auto-dry cycle or the sensors inside the drum are not reading properly.
Dryer runs, but does not turn off
These causes are just like the last topic, but most likely is in your timer.
j0391100.jpg Dryer door does not close or keeps popping open This is a simple latch problem. It is usually in the receiver part of the latch, but replace both sides when you get the kit. Also on matching front load washers and dryers wher you have 2 latches, it is extremely important you put the right latch in either the top or bottom. The Whirlpool latch kit specifies which color(strenth of hold) latch receiver either goes in the top or bottom.
Dryer runs, but produces no heat(non vent problem)
Most of the time, this is caused by either an open heat element, hi-limit cut-off switch, or operating thermostat. Occasionally your timer or control can be the cause, and also don't forget to check for those loose, broken wires or connectors.
Dryer runs, but seems to be cycling too often(non vent problem)
This problem is not to common if your dryer vent is good. The main cause of this is usually an operating thermostat or your timer/control reading the info it gets wrong. Usually when a thermostat goes, it just opens and no heat is produced.
Dryer runs, but gets too hot, never cycles off(non vent problem)
This problem usually means you have a short somewher in your dryer. Most likely the heat element. A lot of times, when this problem occurs, your dryer can even heat up when it is off. The element has either broken off and welded itself to the element side or something has gotten into the element. We have seen metal underwires from bra goe through the holes in the back of the drum and lodge themselves inside the element. This creates a dead short and always heat situation.
Dryer runs, but sounds like tennis shoes inside or scraping noise
Let us state this first, Whirlpool and Maytag dryers use roller supports in the back and either rollers or a slide/seal for support in the front. One noise you will always get with these type of dryers is a constant "thump" noise. This noise is caused by the seam of the drum going over the roller support. Nothing you can do about this thumping noise, and depending on how smooth this seam is, depends on the sound level of the noise. Whirlpool and Maytags also use felt drum seals that are attached to their drums.
GE and Frigidaire drums have a center support in the back of the drum and a system of slides or felts in front to support the drum. No seals are actually attached to the drum itself. Now back to the problem.
The tennis shoe noise is usually associated with a bad roller support and will be more common on the Whirlpool and Maytag brand dryers. When replacing the Whirlpool back support rollers, make sure the support axle is coming out straight from the back bulkhead. A bent axle will cause premature failure of these rollers. A lint buildup will also cause premature failure of the bearing part of all rollers. These rollers are held on by either a triangular plastic clip or a spring clip.
The scraping noise may be caused by either something getting stuck in either a dryer seal, felt or slide, or the noise can be from worn drum seals, worn front felt/slides, or a worn center back support. To fix any of these problems, you must know how to get into the front of your dryer and disassemble the drum. Inspect all rollers, seals, felts, slides, or supports. Replace the defective part.
Dryer repair is not rocket science. It can be done by many, if you think you can do it and need some more help, just drop us a line and we will do what we can. We will also be offering DIY Manuals shortly. If dryer repair is not for you, and you would like to schedule service, just click here and fill out the request form and we will get back to you as soon as we can. If you would like some maintenance tips to prevent dryer repair, click here or go to our dryer vent issue page. The dryer vent is the life blood of your dryer.
please comment on these solution by voting or rating on how helpful
Posted on Dec 30, 2010
Gear selection, unable to engage any gear
IF a cable selector check for missing pin or broken cable or loose outer cable. If mechanical selector check for broken arms or rods
PLEASE RATE THIS REPLY FOR ACCURACY
Mar 24, 2013 | Cars & Trucks
Model GSD3620Z02BB - The normal cycle will not engage when the knob is turned. The short cycle will engage (sound like it is working) but the soap is left in the reservoir and about 2 inches of water is...
Sounds like the selector switch has gone bad. The machine is not fully cycling thru and draining because the selector isn't proceeding like it should.
This typically happens if the selector dial is spun real hard repeatedly over time. The little cogs inside of the selector will get broken and sometimes the broken parts will lodge inside the switch and cause jams.
May 27, 2011 | Maytag Dishwasher
My dryer will spin and then stop spining reading err68 or err4a what can this mean.
E4A = The drying time has exceeded program time for cycle. Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for any thing that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closetwith solid door, or bad connection in moisture sensor bar cir cuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
68 = One of the keys (buttons) is stuck closed (active). Enter function testmode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control
Dec 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
My car sometimes will shift into reverse but is actually in first, any suggestions on what might be wrong?
VECHICLE JUMPING OUT OF GEAR.CHECK FOR WORN OR IMPROPERLY ADJUSTED LINKAGE.THE INPUT GEAR BEARING RETAINER BROKEN OR LOOSE.CHECK SHIFT LEVER GATE SELECTOR CABLE BOLT FOR LOOSENESS UNDER THE SHIFT LEVER BOOT IF BOLT NOT LOOSE THE GATE SELECTOR CABLE NEED ADJUSTMENT.
Oct 14, 2010 | 2002 Volkswagen Jetta TDI
Bike is not selecting E gear when changing gears
its in the gearchanging mechcanism,worn,, slipping,,loose bolts on selectors splines worn or broken the pegs on the selectors broken so not engaging with the slots in the gearchanging disc
Nov 17, 2009 | 2004 BMW R 1150 RT (ABS)
The cycle selector knob turns very fast and the wash goes from the fill mode to the drain mode and does not wash or spin.
the problem is with the selector.behind this,ther is a wheel with teeth.one of the teeth must be broken,causing the selector to turn too fast.
Nov 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire dryer error E4A dryer will run for about 45 seconds then shutoff and start beeping and showing the above error code
This is this is the "program Timeout Fault". Meaning the drying time has exceeded program time for that cycle.Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, or bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 08, 2009 | Frigidaire Dryers
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
265 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
