Question about Rancilio Silvia Espresso Machine
The water stopped coming out of the group head so I took the damn ting apart. Espresso parts everywhere... I can't figure out how the water flows through the boiler then on to the group head. Any advice out there..?
  • 1,089 Answers
Hi
It was probably your 3 way valve. Its located behind the panel below the group head. 2 screws and it slides to the right only. Remove the black nozzel then the #14 nut on the bottom of the 3 way. Solenoid will slide off. There are 2 screws holding the 3 way on. Install the new 3 way in rreverse. and you will be good to go.
Posted on Dec 31, 2010
Direction replacing goup solenoid
As you have put it water flows from boiler to group head so the arrow on the solenoid should be this direction.
Aug 15, 2012 | Pasquini Livia 90 Espresso Machine
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
The left group head on my GB5 is not engaging.
Remove the diffuser screw and screen and check the holes in the screws, they might be blocked, press brew button with screen removed to see if you have water flow.
May 06, 2010 | La Marzocco Linea Series Group 3 Espresso...
I don't have enough water pressure to make cofee. Very little water comes out of the shower head. The shower head is clean, it is not plugged. I suspect it is the pump? Please advise
I had the same problem: clean showerhead, machine pumps hot water just fine, but very little brewhead flow. Descale made it worse but that was a big clue! I took apart the brewhead and found grains of scale in the boiler, like pulverized beach shell:
Some of those bits apparently made their way into the three way valve and clogged it. I could not blow air through the channel between the plunger and the boiler. Not surprising: the inlet hole inside the valve is TINY and clogs easily.a0bc8304-2405-4fdb-a444-21cf80e7701a.jpg
Once I got this part cleared up inside (and cleaned out the rest of the scale from my boiler so it didn't immediately re-clog!), my brew flow was restored.
Sep 05, 2009 | Gaggia Classic Espresso Machine
Grouphead not dispensing water
Remove the shower screen and press button to brew, if water flows the the holes in the screw/diffuser is blocked, if water does not flow then the blockage is at the solenoid or within the group head chamber. This problem I have notice when someone brewed without the shower and screw in place.
Jun 29, 2009 | La Marzocco Linea Series Group 3 Espresso...
No water coming out of the group head?
Your problem is either the brew solenoid or the brew switch.
Feb 09, 2009 | La Marzocco FB-80 Series 3 Groups Coffee...
Leaking saeco (barista starbuck) portafilter
The boiler and the portafiltre both are bolted together at the same time, otherwise the spacing is wrong. Took me a long time to figure it put...
Nov 24, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Oct 18, 2008 | Pasquini Livia 90 Espresso Machine
Low water flow from gaggia evolution only 6 months old, have tried descaling, no obvious scale found in machine. pump starts but goes quiet, very feeble flow of water.
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Apr 29, 2008 | Gaggia Baby Espresso Machine
Rancilio Silvia Espresso Machine Logo
167 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
