Question about Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver
Minn Kota lower unit leaking. Have brush replacement kit. How do I insure a good seal upon reassembly?
    Problem Solver:
  • 8 Answers
Man, you have a job ahead of you. First, if the unbreakable shaft is cracked or broken, you will have to replace it, for it will leak into the motor too. If your unit has the sonar sensor in the front and it has had water in it, the unit can corrode severely and need a lot of parts besides seals. The wiring to the sonar runs in a protective shield bonded to the magnet housing and one of the long screws holds it in there. Remember to take the wiring to the sonar out AFTER you remove the big motor feed wires, and replace it BEFORE you reinstall the red and black cables. Some grease seems to ensure the o'rings slide on metal parts during reassembly rather than tear. It's quite a job.
Posted on Nov 28, 2008
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    CAN YOU REPLACE BRUSHES
    Sure can! Chances are if you need brushes, you should do a clean up of the motor as well. If there has been no water intrusion then the job is fairly easy, if water has gotten into the motor you'll need to spend some time and elbow grease cleaning it out . Always replace the seals, they come in a kit and are inexpensive. At a repair shop average repair bill shouldn't be more than $70-90 for this including parts. Parts can be purchased here: www.mikesreelrepair.com
    Jun 13, 2011 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    I have to manually turn the prop. to get the Minn Kota electric motor to work. Once it gets going it works fine. What is the cause?
    I have an all terrain 70 that would not work intermittently. I disassembled the motor and discovered that the brushes wer hung in the brush housing. The housing is clean and the brushes are in great shape. It appeared that the geometry of the brush spring is just right to make it hang at that prticular position. I freed the spring and could not recreate the problem. Reassembled with new gaskets and seals and all is good.
    Jul 05, 2010 | Minn Kota Maxxum Pro 80 Freshwater Transom...
    How to get wires out of the shaft?
    carefully drill out
    the screws the are not removable to remove the cover. you will have to take apart the motor housing marking the outside for orientation for reassembly. this is critical as it could run backwards if improperly reassembled. you will need a seal kit for the motor as well. the wires that go to the coil pack in the nosecone are not removable. call the 800 number on the upper part of the motor for minn kota to ask any questions and to order new screws and a seal kit and any other needed parts. make sure motor is not attached to the battery at any time you are working on it. good luck.
    May 31, 2010 | Minn Kota Edge 40 Freshwater Bow Mount...
    We have boat that came with trolling motor, boat not used in 5 years what should we do to service the motor/minn kota 40at before we put in water we hooked to battery it spun and quit?? not sure what to...
    My guess is the motor has leaked water into the lower motor assy (behind the prop). and needs to be cleaned up and the brushes replaced.
    here's a schematic:
    Edge 40
    You can try this to check for water leakage:-
    1) disconnect from power supply
    2) remove the prop
    3) you will see 2 bolt heads behind where the prop was. Remove ONLY ONE of them for now.
    4) if you see the bolt (it's about 8" long) is covered in what looks to be blask, oily/watery or rusty condition then you know that you'll need to overhaul it.
    5) if it IS the motor assy, remove the other bolt and disassemble everything noting their location.
    6) I would recommend replacing the brushes Part# 188-052 and the seal kit 2883460.
    Sep 23, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    My endura 30 lower unit was filled with water and mud/rust. It was working all speeds before I opened it up. I had to hit the lower unit sometimes to get it to spin. The armature contacts have many pits,...
    You *may* be able to save the armature (about $45) by using some fine emory cloth to buff it back to life.
    The brushes, seal kit, bearing, etc are about a $35-$40 bill. To have it done in-shop would be approx. $80 with labour.
    Here's a schematic:
    Endura 30
    Good luck in your repair!
    Mike
    Sep 23, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota all terrain 65 problems
    Hi!
    Here's a schematic for your motor:
    Max 70
    My guess is you are correct in it being the brushes.
    More times than not the motor will have leaked from in behind the prop are. What happens is a peice of monofilament line floating around in the water gets caught behind the prop and cuts the seals up, allowing water intrusion.
    To remedy you'll need to clean up the entire bottom motor and replace the brushes, bearing and seal kit too. Clean up the commutator (copper area, now probably black in color, where the brushes ride on) with fine emory paper and you should be good to go!
    Best of luck
    Mike
    Sep 16, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
    Hi!
    Here is a schematic for your motor:
    Endura 30
    It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
    Best of luck!
    Mike
    Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
    I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
    Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
    I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
    Good Luck!
    Jun 09, 2009 | Boating
    GPS Logo
    1,417 people viewed this question
    Top Minn Kota GPS Experts
    Will Halftowaite
    Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
