Question about HP Pavilion dv6000z Notebook
How to replace a lcd screen on a notebook - HP Pavilion dv6000z Notebook
    Scholar:
  • 149 Answers
1) Remove screen bezel by removing the screws (covered by rubber discs) Pry it away from the frame.
2) Unscrew the LCD frame from the back plastics. You may need to deroute cables and unscrew your webcam or other screws.
3) Pull your lcd out and forward. Remove the tape securing the LVDS ribbon cable to the monitor. Deroute the cable. Remove your 2 (sometimes 3) pin backlight cable (usually located near the bottom of the panel)
4) Remove any wifi antenna cables or webcam cables that are in the way.
5) pull out your old screen and install your new screen. If the new LCD doesn't have a frame installed, remove the frame from your old LCD by unscrewing the screws on the sides of the LCD.
This is completely from memory, so there may be a mistake or two. It's not hard to figure out by yourself once you've removed the bezel, though.
Posted on Dec 30, 2010
  • HP Master
  • 2,385 Answers
Hello
Here is the detail pictorial view of replacing screen of dv6000
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
Good Luck, and do rate the solution if got help
Cracked lcd hp g6 notebook screen
if you want to replace the screen i suggest to replace the whole unit.since its hard to find lcd screen only unless in the manufacturer.then i'm sure the price is like you buy new one.
Aug 29, 2012 | HP Nx7400 Notebook Pc 15.4-inch Wxga Tft...
In my dellvostro a860 , rite side of the screen colours are spreaded,it it looks like shade,,whats the problem in that i m not getting please help me..........
It is the screen Inverter, or the LCD screen itself.
Screen Inverter: A small circuit board located behind the Display Bezel, and mounted towards the bottom of the LCD screen,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/display.htm#wp1183775
The yellowish long object, at the bottom, is the screen Inverter.
Here is another look at it,
http://www.batterycenturys.com/dell-vostro-a860-inverter-p-185294.html
Dell Support > Vostro a860 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
In the list clicking on -> Display, will get you to the first link above.
Need guidance in replacing the screen Inverter, post in a Comment.
(Just a basic guide using a Vostro 1014/1015 Notebook PC. Not yours, but good for basic guidance. This is replacing the LCD screen,
http://www.insidemylaptop.com/replace-lcd-screen-dell-vostro-1015-1014-laptop/
[ Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
( Click on the small window with the monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (or more than one), or a series of LED's used as lights.
The Dell Vostro a860 Notebook PC uses one CCFL, for a Backlight, OR there are Vostro a860's that use LED lights.
(If you replace the LCD screen, make sure FIRST of what type of Backlighting it uses)
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness of a CCFL is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Most of the time the fault is the screen Inverter.
The Vostro a860 Notebook PC's, that uses LED's as a Backlight, MAY also use a screen Inverter.
Primer over.
For your problem it could be the screen Inverter, but I lean more towards the LCD screen itself, is the problem.
How to test a screen Inverter? Requires a very sensitive multimeter.
Read; Expensive,
http://www.fonerbooks.com/test.htm
For a layman who does not have access to a sensitive multimeter, the method is to just replace the screen Inverter, and see if it is the problem.
'Parts changing', I know, but if you do not have the proper equipment to test with?
Screen Inverter replaced, and problem still persists, replace the LCD screen,
http://www.laptopscreen.com/English/model/Dell/VOSTRO~A860/
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Dell Vostro A860 Notebook
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
The display system of the vaio notebook went dim then finally died out.what is the possible problem and solution to the same
Hi akeyow..
Sounds like you have either a bad lcd screen or a bad lcd inverter.
To check to see if the screen is bad, connect the notebook to an external monitor that you know is working...if it works the you will have to replace the lcd screen.
If it doesn't work then the internal lcd inverter, will need replacement.
Both replacements take a better than average skill to replace, maybe best left to the pros...or sometimes you can check out YouTube and some people show you how to do it.
Sony lcd replacement:
http://www.screentekinc.com/Sony_Vaio_VGN-CS_Series_VGN-CS215J~W--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is a link to the YouTube webpage for replacement, could not find your model, but I am sure you could use some of the info to replace what you have...
http://www.youtube.com/results?search_query=Sony+VAIO+VGN-CS215J%2FW+screen+replacement&aq=f
Lcd replacement, lcd inverter replacement
Aug 22, 2011 | Sony VAIO VGN-CS215J/W Notebook
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
Apr 03, 2011 | Computers & Internet
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Need replacement LCD Display Screen for my HP Pavilion dv9730us 17" Notebook PC Laptop. Where can I get one for a low price?
If the LCD screen is not physically broken ie a cracked screen then it could have a faulty inverter or a faulty CCFL lamp which will give you a black screen. The inverter and CCFL lamp is a lot cheaper to replace than a complete new LCD screen.
Check out LCD Parts WEB site for service, parts and DIY info. Click on this link to their WEB site :-
www.lcdparts.net
Feb 05, 2010 | HP Pavilion dv9730us 17" Notebook PC -...
HP Screen Shatter.
According to my openion, It is better to purhcase a new Notebook rather than replacing a screen. Becuase, LCD of a notebook costs around $600. Where as you can get a new notebook for $600- $1200.
As LCD is the major part of the notebook, it is always bettery to purhcase a new notebook rather than repairing it. However, if it is the only issue with the LCD, you can use the notebook by connecting to an External Monitor through VGA port.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv6000z Notebook Logo
120 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
