Question about Minolta X-370S 35mm SLR Camera
I cant see through the view finder...its completely dark and the film advance lever is stuck. the lens is fine and the cap is off and theres no film...it was never bumped or scratched...what gives
    Scholar:
  • 175 Answers
Remove the lans and make sure the mirror is in the down position. If not, then camera repair is probably needed.
Posted on Dec 31, 2010
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
My film advance lever is stuck. pushed button under camera didn't work
You may have hit the end of the film. Rewind the film back to the spool until the very end gets back in the shell.
If you think you still have unexposed film do the following. Rewind about 1-2 full rotations. Cover the lens using the cap. We're doing this so that step 2.3 will not spoil your last pictures. Take 2 shots (with the lens cover). This time the button at the button should have popped out.
Feb 28, 2011 | Canon EOS-AE-1 35mm SLR Camera
My FA camera shutter release button won't work, no reaction when depressed and look through the view finder was dark.
The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two SR44's or LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
Feb 18, 2011 | Nikon FA 35mm SLR Camera
The view finder is black, how can I clear it?
It sounds like the mirror is stuck up! You can check this if you remove the lens and look at the mirror. If it is horizontal and all you can see is the film plane (black box), then it is stuck up. If you are lucky, your camera may just need new batteries. Worth a check too that the shutter speed is not set to "B" and the lens cap is left on. If the camera has sat for more than about 6 months, the batteries will definitely be dead.
Oct 17, 2010 | Olympus OM2 SPOT/PROGRAM OM2SP SPARES OR...
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Fuji FinePix F710 photos blacked out
hi
i think the settings on the exposure or apparture have been modified
reset the camera to factory defaults once to check this and you can have the photos back in order
happy clicking, enjoy
pls rate if this was any help
Jul 13, 2009 | Fuji FinePix F710 Digital Camera
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Sep 12, 2008 | Ricoh XR-10M 35mm SLR Camera
Dark view in view finder
Sounds like a lens diaphragm problem ( lens stays closed down to F16 and that is why you have a dark viewfinder ). Remove lens and see if you can activate the aperture mechanism via the activator which protrudes from the rear of the lens. You should get nice and brisk action from the aperture . If the movement is sluggish or the lens stays fully closed then your lens needs attention.
Sep 15, 2007 | Nikon N75 35mm SLR Camera
Minolta X-370S 35mm SLR Camera Logo
185 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
