Question about Behringer EUROPOWER EP2500 Amplifier
Clipping the channels - Behringer EUROPOWER EP2500 Amplifier
    Brigadier General:
  • 8,546 Answers
The manual discusses the Clip Inidicator and how to deal with clipping.
Clipping in this amp isprimarily a function of the input signal being distorted so the input level is recommended to be lowered. Beyond that the cause of input distortion would have to be addressed in the device producing it.
http://www.retrevo.com/support/Behringer-EP2500-Amps-manual/id/23281ci655/t/2/
Posted on Dec 30, 2010
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
Why channel A clipping on soundcraftsmen ma5002a what's wrong
When you have a DC voltage on the output, check your capacitors in the amp. Looks like the big electrolytic is defect.
I don't have a manual of this amp, so I can't verify if I'm right and what cap you should look for.
Nov 21, 2014 | Audio Players & Recorders
How do I replace the c clips part #ecx 1014?.
using a plier or channel lock, place one foot on open end of clip and other foot on shaft. by squeezing, it should pop off. (dont lose it) option B is that you can place a tiny flat head screwdriver into hollow on C clip and lever it off.
to put new clip on, use channel lock. with one foot on back of clip and other foot on free section of shaft, squeeze clip and it should pop on.
Jul 01, 2014 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
B channel cuts off after a few minutes
Speaker is blown or amp channel is. Swap channel connections from a to b, etc, and test channel again. If it doesn't clip you have your answer. If it still clips out, your amp has a blown channel.
Apr 20, 2014 | Pyramid Zpa150 1500-watt Professional...
How to clip and tune
why do you want to clip and tune a radio? Clipping the diode will make the radio modulate higher and unrestricted but if you take that radio and turn the power down to 2 watts give variable 4 a full turn to the right and open the modulation pot it will sound a whole lot better then if you clipped it. when you clip a radio you create a splash box that wipes out all channels lose by and the others will also be effected. the diode you want to clip is D-11. but I advise you not to.
Nov 24, 2013 | Uniden Bearcat Pro PC68Elite 40-Channels...
Clip light on
Does all the "Clip" lights are on? or just certain channel? if all "Clip" lights are on you have to check the +15V and -15V at Operational amplifier ic that is a 8-pin integrated circuit, pin 4 should have the -15V and Pin 8 should have the +15V, if just one channel shows the light constant on then its an opamp in that particular channel, let me know further to improve help.
Oct 24, 2013 | Peavey PV8 Mixer
Channel 6 clip led on constantly.
Is the channel clipping or just the LED stuck on?
Should be an easy fix if its just the LED.
Jun 30, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Crown CE1000 and CE2000 both clipping with low signals
for some reason channel one of one of our amps started clipping. i first noticed it with the drum kit but it slowly moved to the vocals as well. i haven't noticed this issue before today. what do i need to adjust to keep it from clipping?
Jun 04, 2010 | Crown CE2000 2-Channel Amplifier
My yahama P3500s Amplifier left channel dead and clipping light stays on both speakers works ok in right channel.
Hi, make sure everything is disconnected, is the clip light still on?
if so then I'm afraid it sounds like the output devices for one channel may have blown, ( not certain, without looking at it i'm afraid ).
If you need more help, then please ask.
Regards - Anthony
Feb 06, 2010 | Yamaha P3500S Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
152 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
