Question about Sennheiser Audio Players & Recorders
The diagram shows that the ear phones are supported by a metal rack. is this required. i didnt get one.
    President:
  • 1,348 Answers
It is not as long as the headphones are supported properly.
Posted on Dec 30, 2010
KENMORE ELITE #86013 Microwave/Convection Oven:Manual says always use Metal Rack when convection cooking.How can you cook whole chicken or roast? If you put food on top of the rack it will rub against
Yeah, that's an interesting dilema. You need to lift the food off the tray to get proper air circulation, but I've seen those racks and I understand that you don't have enough room to put a full bird in there! Is that by design, or an oversight? I don't know! And what can you do about that? Maybe you can cut off an inch off the support legs of the metal rack....
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Microwave Ovens
Maytag Microwave MMV5207AAQ
its common to all ovens! causes are food spills and oil spills left uncleaned! painting only might fix the problem for a while, but it won't give you a lasting service!!
! you should buy a new rack for much safer use!
keep in mind also to clean the oven after every use! (let it cool first of course!)
Dec 09, 2007 | Microwave Ovens
My JVM1350 has metal rack inside. How do I use it. I thought you couldn't have any metal inside.
on the inside of micro.. the rack is supported with plastic clips.. this allows stock part metal rack work
May 26, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
How do you install the rear rack ears
I don't know about the Peavey amp but most have rack holes that run parallel with the amp's side panels. On the rear of the rack this requires a mounting kit unique to your rack (provided there are mounting rails present) or some creative strapping to properly stabilize the amp. I've seen tech's anchor the rear mounts to the inside of the rack walls. Wood is easiest (and strongest) to work with but fiberglass mounts with fender washers also creates a pretty strong mount....G.
Dec 06, 2010 | Peavey Pv 2600 Power Amplifier
Only one ear phone work
Check Following Instructions:
- Connect your ear phone pin properly to your MP3 Player.
- If one ear phone not working - check ear phone wire is break - connect wire metal correcly.
your ear phone will working.
Apr 13, 2010 | Archos Internet Media Tablet MP3 Player
My microwave sparks inside where the metal rack rest on the plastic holder
You will need to remove the rack and all the rack holders.
Any grease or carbon arcs will have to be cleaned thoroughly, and if the metal is charred or damaged, you will need to apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Then replace all of the rack supports, not just the one that arced.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 06, 2009 | GE Microwave Ovens
My microwave is making a weird noise and also a flash of light is coming off.
If yours has a metal rack, it may be arcing at the rack holders.
If so, you will need to remove the rack and all the rack holders.
Another common cause of
such noise and flash is grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
Sometimes it is a circular piece in the ceiling of the oven.
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
Dec 06, 2009 | Maytag Jenn-Air JMC9158B 1000 Watts...
HOW TO PUT DRYER RACK INTO WHIRLPOOL CABRIO #WGD6600VWO
If it is a dryer with the lint screen on top place the two ends of the metal loop into the two holes closest to the plastic clips on the bottom of the rack. The clip the metal bar down into the clips and the multi-bent part of the metal ring are now atteched to the bottom of the plastic rack. Turn it over and place the metal ring in to the back of the dryer and the front lip of th plastic rack then hangs loosly over the lip of the bottom of the opening of the dryer. It will all tighten up when you close the door. Hope this helps
Apr 18, 2009 | Whirlpool Cabrio WTW6600SBK
Micowave sparks a fire
I had the same exact problem. My clips arced when I ran the unit and I also observed flames which was quite unsetteling. A work around for me, since I don't use the rack was I took it out then removed the clips. All that was required to remove the clips was a pair of plyers grabing each cliip at their base. I pulled firmly and there is alittle resistance but with a firm pull straight out they'll pop out.
But I have to say if you use rack your probably looking for a new mircowave.
Dec 27, 2008 | Whirlpool MH1150XMQ Microwave Oven
Sandisk M250 ear phones Jack information 2.5 or 3.5 ?
It's the larger headphone minijack standard on most portable tape players etc., not the much larger one found on hime stereo equipment or the smaller one most often found on cellphones. So, "3.5" (mm?), I suppose.
Nov 10, 2008 | SanDisk Sansa m250 MP3 Player
217 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
