Question about Sony Watchman FDL-22 2.2 in. Television
Tv reception on handheld Sony Watchman in Feb 2009
I have Sony Watchman FDL-22 handheld TV with internal antenna. Is there an attachment that can be used after tv reception goes digital in Feb 2009?
  • 1 more comment
  • starksville Aug 16, 2008
    Just a followup on this problem. My wife has this TV and uses it when we go on trips. Any reasonable ideas on how to keep using the TV after Feb. 2009 would be appreciated.
  • Anonymous Oct 17, 2008
    will portable tv's work when tv goes digital?
  • Anonymous Mar 10, 2009
    where do I find an external antenna that will allow me to connect my cable to this little tv?
The old Watchmans are analog. If plugged into a digital cable/dish system it will scan in UHF and find the working channel than can be conrolled by your digital remote control. As far as taking it out on its own and working off the external antenna...those days will be over. Sony will have to manufacture digital Watchmans.
Posted on Feb 10, 2009
Hold on to those sony watchman, the goverment is going to auction off the analog. You just never know what might pop up lator.
Posted on Jun 12, 2009
Does the SONY FDL-PT22 work any longer with VHF/UHF options? I get no picture no matter what I try. Thanks Beth
all channels are now being broadcast in digital format.You set will not pick up channels because it does not have a digital tuner..
Sep 23, 2011 | Sony Watchman FDL-PT22 2.2 in. Handheld...
PICTURE WILL NOT APPEAR ON SCREEN
First, I would check to see if the AC adaptor is working. If you are on batteries instead, look for corrosion on the battery housing-usually on the springs
May 28, 2010 | Televison & Video
Watching TV on my SONY FDL-310!
Any of the digital to analog converters should work. Connect the converter RF OUT to a COAX cable, connect the wire in the center of the COAX cable to the Sony antenna with an alligator clip type patch cord. Tune the sony to the proper channel (3 or 4). Voila!
Jun 24, 2009 | Sony Watchman FDL-22 2.2 in. Television
Cannot get picture on my Sony Watchman TV/Radio-just standby flas
May have something to do with the switch to digital tv that occurred back in Feb.
Apr 20, 2009 | Sony Watchman FDL-250T 2.5 in. Handheld...
Will Digital Converter Plug in to 1993 Sony Watchman?
Yes,you can use the audio/video input jack on the TV with a connecting wire (mini-plug on one end,RCA plugs on the other) hook other end to output on converter box.
Jan 29, 2009 | Sony Watchman FDL-250T 2.5 in. Handheld...
most will work if they are a newer model
Dec 04, 2008 | Sony Watchman FDL-220R 2.2 in. Handheld...
Need info before buying one.
The Sony KV-32S120 has an analog tuner. If you use it with an antenna, you'll need a digital converter box. If you're a cable tv subscriber, the cable company will do the conversion and you won't need anything. Here's what Sony says about it...
http://esupport.sony.com/perl/news-item.pl?news_id=256&mdl=KV32FS120
Nov 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the HD LCD model 40X787. To program the channels I have to scan in analog and then the programing will associate it with the digital HD channels. What will happen after feb 2009 when there is no...
The only people effected by the changeover are those that use external antennas for TV reception. I am assuming that you use cable or satelite correct?
Dan
Apr 17, 2008 | Televison & Video
Digital reception
Check the menu screen to see if you have an option to program digital channels . If not the answer is no . If you are on cable or satelite then you need not worry as the only people who will be affected by the digital change over will be if your on outdoor antenna or rabbitt ears only with your tv. Your cable and satelite providers will not change you over on feb 19th 2009 . Everythung will be the same . Good luck
Dec 28, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
2,467 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
