Question about Nikon N2020 35mm SLR Camera
Meter will not work - Nikon N2020 35mm SLR Camera
    Sergeant:
  • 435 Answers
Is the battery for the meter good ?
Posted on Feb 13, 2015
How to convert from cubic meter into square meter
You don't. Cubic meter is a measure of volume while square meter is a measure of volume.
For example, consider a room that's ten meters by ten meters, The room is 100 square meters. Now consider a ceiling that's two meters high. The volume is 200 cubic meters. Then raise the ceiling a meter so it's three meters high. Now the volume is 300 cubic meters, while the area is still 100 square meters.
Oct 30, 2016 | Office Equipment & Supplies
Trip Meter not working.
Odometer and Trip Meter Stopped Working - AcuraZine Community
acurazine.com/forums/.../odometer-trip-meter-stopped-working-757772/
Dec 29, 2009 - The tech said he has seen the odometer & trip meter not workingbeing ... I have a 1997 TL and the same exact thing happened to me today. speedometer,trip and odometer not working
Aug 5, 2012
Cannot reset Trip A or Trip B on New 2012 MDX
Aug 1, 2012
Trip meter resets itself
Jul 25, 2012
Trip Computer Reset feature (with refuel) question..
Dec 19, 2009
More results from acurazine.com
Acura TL odometer trip meter not working Questions ... - Fixya
www.fixya.com/tags/odometer_trip_meter_not_working/cars/acura/tl
Dec 15, 2015 | 1997 Acura TL Series
Superstar 3900 meter not working
Need more info, is the wires soldered on, has one broken, on board do you get a reading an not on meter? Could be meter or poor solder or broken wires. Because you dont get readings at all, tells me its more likely the meter or connections
Mar 23, 2014 | Superstar 3900
Meter light and meter does,not work
this is a questionable thing. The radio I am using doesn't have a meter light but the meter works.I don't pay much attention to the meter anyway as I have a Dosy hooked up to it at all times. It will not affect the radio out put or input so you may think of getting a small meter to put in line and leave it at that.
Mar 09, 2014 | Cobra 29 LTD CB Radio
How does the moisture meter work?
EHow says: Electrical power is easily conducted through a moist or wet environment. When wood fibers contain moisture it can also conduct an electrical signal or voltage. This allows the moisture meter to act as a signal generator. The signal generator will output a small voltage into the wood fibers. The small voltage is typically supplied by a battery. The moisture meter contains an internal circuitry much like an ohmmeter. The ohmmeter reads the amount of resistance that an electrical circuit may employ in conducting electricity.
Read more: How Does a Moisture Meter Work? ' eHow.com http://www.ehow.com/how-does_4924697_moisture-meter-work.html#ixzz2JRaS12Xt
Jan 30, 2013 | Measuring Tools & Sensors
With my rf gain all the way up i dont get needle movement and when i transmit the needle only move to about 2. not sure what is wrong
It could be a bad meter in the radio. there is know way to know without hooking the radio to a watt meter to see what it's really doing.
If its just the meter, its not a real problem. Some time dirt gets into the workings of the meter, and especially if it is a metallic debris, it will gum it up because there are magnets in the meter, and metallic debris sticks to it locking it up. Some times lightly taping the radio above the meter while modulating will loosen it up, but that would be a temp fix. The meter would have to be replaced. Careful when taping the radio, you don't want to cause more damage.
If the meter is just gummed up, the meter is not integral, and if it doesn't mater to you if the meter works right as long as the radio works, then you can leave it.
Aug 13, 2011 | Connex 3300 240-Channels Base CB Radio
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
Aug 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Light meter not working
Make sure the battery lid is securely screwed on, The meter wont work before the '1' frame. i just found out last week about this. make several clicks till the '1' mark appears, now check the meter if its working. [A] - aperture prio
Jun 09, 2009 | Nikon F3 35mm Film Camera
Speedometer does not work, but odometer works all the time.
clocks are dead its a common fault they come on and off intermittently i had the same fault you need to replace your clocks
Feb 12, 2009 | 2003 Ford Focus
Q45 airflow meter wiring.
That's not going to work. You can't install a air flow meter into a Pulsar from a Q45. Totally different animals. Air flow meters are car specific. I don't think its gonna work, but good luck with that.
Sep 28, 2008 | 1998 Nissan Maxima
Nikon N2020 35mm SLR Camera Logo
134 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
