Question about Fisher and Paykel GWL11 Top Load Washer
I get black flakes on clothes after a wash - Fisher and Paykel GWL11 Top Load Washer
Waht causes black flakes on clothes when washing?
Hi, it sounds like you have to buy one of the inside washing machine cleaners its a liquid that you put in the washer and let it run its cycle to flush clean the interior of the unit.
Jan 23, 2016 | Samsung 4.8 Cu. Ft. 13-cycle...
What kind of cleaner should I use for my clothes washer ?
We had black flakes getting into the wash drum thru the drum holes. We ran one gallon of white vinegar through a regular cycle with great success.
Oct 04, 2014 | Bosch Vision 500 Series Front-Load Washing...
Is there a filter in the machine that \i should be cleaning as i keep getting black bits on the clothes?
The black bits are scum flaking off from between the inner & outer bowls, usually more common with cold water wash. Place old towel in washer, fill washer to high level with hot water, add washing soda & or vinegar, let washer run to end of wash cycle, turn off & let it soak for around an hour, turn back on & let it go through cycle. Commercial washing machine cleaning products should also be availably in your supermarket / hardware stores. You may need to repeat process until no more gunk comes out.
Dec 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher-Paykel washer, about 8 years old, leaving specks of something on clothes. If the "specks" are intact I can lift them off clothes with toothbrush; however if load spins fast, then I get streaks that...
Hi just read your posting.Now you mentioned that the specks are not lint.In my service manual it states that if you use fabric softener then this can build up in the bowl and leave black flakes on the clothes.Try filling machine on a hot wash and pour into bowl 1 or 2 cups of automatic dish washing power and leave the machine to soak overnight.In the morning restart cycle and let it go all the way throe.Please reply on how this worked and for further advice.Looking forward to your reply.
Oct 08, 2010 | Washing Machines
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
After washing whites clothes covered with black bits
your lip seal is leaking and the bearings are getting water in them,you need to get this fixed soon,because they can lock up if left too long like this and it will only get noisier and not better with time
May 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Flakes of dirt on washing
Is this perhaps a second hand machine or it has possibily been stored away for some time? When a washer dries out inside ( behind the washer bowl ) and is then put back in service, dirt from years of use caked on insides flakes away ( like a dry leaf crumbles) and re-enters the wash and can end up on washed clothing. The only way to stop this is complete removal of washer bowl , scrub and clean insides to remove caked on dirt - reassembly. problem fixed !
Jul 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
61 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
