Question about Kenmore Washing Machines
Kenmore Elite washer will not agitate after fills with water. It appears that the switch in the lid is broke. Tried to lift up the top of the washer (where knobs are...but could remove all but the big dial. It would not budge. Do you have any advice?
  • 413 Answers
The knobs do not have to be removed......
To access the lid switch, first lift the console by one of three ways.
  • 1. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
  • 2. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
  • 3. insert a putty knife under each corner, push to release a latch.
With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
If you need further assistance, let me know
Posted on Jul 08, 2008
Washer not agitating or spinning
check the lid safety switch just underneath the top cover,they will appear non-functional if this switch goes bad, if all it will do is fill with water,then do no more,you need to remove control panel and outer case to replace this switch
May 05, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
The contact button (part where you put the door down to make the washer start to agitate) something came apart....washer is filled with water and now won't go. The part came out.
you broke the lid switch,send the full model number located under the lid,lift the lid up,follow the lid to the bottom and look right under it and you'll see the model number,it will start with like 110.
Aug 30, 2011 | Kenmore 22422 Top Load Washer
I have a Kenmore top load washer (110-22642100) that will fill, agitate through entire wash cycle, but that's it.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
  • Screwdriver
    • 1
      Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
    • 2
      Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
    • 3
      Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
    • 4
      Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
    • 5
      Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
    • 6
      Locate the water pump at the base of the washing machine on the top of the motor shaft.
    • 7
    • take the cover off the pump and remove any blockage or debris.
thanks and good luck
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer '
May 04, 2011 | Kenmore Washing Machines
Kenmore Elite Model 11023032101 will not Spin
if it agitates and pumps out water it is not the lid switch.  you most probably have a bad brake/clutch mechanism.  the fact that it spins tells me the transmission is good
Jul 30, 2010 | Kenmore 23822 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Lid switch is broke and need to replace.
1. Unplug machine
2. Remove two screws in back of angled top part connecting it to base, lift back up 4-6" and shift top toward front 1/2" so tabs holding front of top to machine base can disconnect.
Mar 27, 2009 | Kenmore 24622 Top Load Washer
I have a Kenmore Elite top loader that does not agitate after its filled with water and the lid is shut. I've tried all speeds.
I had the same problem with my Kenmoore and had to replace the agitator...ordered the part through Sears. Wasn't hard to fix, just needed to wait for the shipment.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Please remember to leave a rating!
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
81 people viewed this question
Sal De
 Brian Main
Brian Main
