Question about LG VX3100
Is there a blue tooth on these? - LG VX3100
  • 37 Answers
Hello ,
No , this model handset won't support Blue tooth feature. It's a pretty told model.
Posted on Dec 30, 2010
No bluetooth can i get an app
Blue tooth capabilities requires hardware chip and programming.
If your tablet does not have built in blue tooth, then the answer would be a negative. If tablet is blue tooth capable, the blue tooth device must be capable to mate to tablet blue tooth version technology.
Feb 26, 2014 | ZTE V9 Smartpad Android Internet Tablet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Aug 16, 2009 | Trust (14694) Keypad, Mouse
I have a sanyo katana , will all blue tooths work on this phone?
Most of blue tooth will work with this phone, but to be on the safe side. Go to blue tooth manufacturer website and check if their blue tooth is compatible with your device.
Nov 14, 2008 | Sanyo Katana® II Cellular Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Blue Tooth compatability
Blue tooth is proprietary and your phone may not have blue tooth
options.Check your user mauual to see if your phone has blue
tooth.
tk46
Jun 16, 2008 | Panasonic KX-TG1033S Cordless Phone
LG VX3100 Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
