Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I DO HAVE A SNOMASTER SM26 ICEMAKER BUT IT IS MAKING ICE BUT AFTER A WHILE THE FAULT LIGHT IS COMING ON AND THEN IT STOP
michaelcanto
  • 76 Answers
SOURCE: no water to icemaker What do I do?
Trace the water supply line looking for kinks behind the fridge, also check the water supply valve and make sure water flows when disconnected from the unit.
Posted on Jul 28, 2009
mgprice
  • 744 Answers
SOURCE: icemaker not making ice
Hi reach up and feel inside the ice tray where the ice is made. If you feel some ice then the ice maker is bad and should be replaced. If you feel in the tray and it is empty then either the water line is blocked or the valve is bad.
The way to determine which is to pull the unit out and remove the lower panel at the back. Trace the water line for the ice maker to the valve, remove the water line from the valve and blow through it. If you are able to blow through the line the valve is bad, if not able to blow through the line there is a blockage. Trace the blockage in the waterline from the valve up to the ice maker and thaw the ice blockage with a hairdryer.
If you have any other questions please feel free to ask. Mike
Posted on Mar 25, 2010
SOURCE: Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Posted on Mar 20, 2009
  • 66 Answers
SOURCE: The icemaker in my ksrs251 quit making ice any
Probaly a fault on water pump.
Posted on Apr 18, 2010
  • 415 Answers
SOURCE: Ice maker stopped making ice.
Ok open your freezer door and observe the flashing red light now push the flapper inwards keeping your finger and hand out of the way of the infa-red sensors you should observe the light it should not flash but glow steady if it does not a fairly simple attempt would be remove the 3 screws on that assembly pulling it away from its location and unplug the harness, now go to the other side and remove those screws and unplug the harness reassemble both sensors and screw back into place push the flapper back in is the red light steady? No then you will need a infa-reds sensor kit I believe they are now well over 100.00. I do hope clearing the pcb on the sensor by unplugging the harness works but if not you now know how to replace the infa-red sensor.........And if the light is working steady and no ice is in the imkr then fill with water and off you go....
Posted on May 14, 2011
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
My Kenmore refrigerator (596.52673200) is making a noise every 3 minutes or so for about 15 seconds. It seems like it is trying to fill the ice maker. There was ice in the little rubber tube leading to the...
Put the icemaker arm in the lock position to turn it off.
If it is the icemaker making the noise, the noise should stop.
If the noise stops,replace the icemaker.
If it does not stop,let us know.
Sep 22, 2010 | Refrigerators
Icemaker won't stop making ice
for safty call the store because of the warranty
Mar 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ge profile ice machine on off light is blinking and not making
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker stopped making ice.
make sure you can see the green light is on which means you have power. if its lit,press and hold the cube size button untill i/m starts to cycle if i/m runs but does fill then your water valve is bad, if i/m will not start then your i/m is at fault
Dec 13, 2008 | LG LFX25960ST Stainless Steel French Door...
Icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
225 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
