Question about Dishwashers
How do I undo the child lock on my fisher and paykel nautilus dishwasher?
SOURCE: dishwasher f1 problem on fisher paykel
先谢谢啦
Posted on Feb 21, 2008
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel Nautilus Dishwasher
F4 is a fault code telling the controller that the water is not heating up. This can be caused by either a faulty heater plate, a bad connection between the plate and controller, or the controller itself. If you wish to fix this yourself, changing the heater plate is a fairly involved repair and should be done by someone with a high degree of mechanical ability.
Posted on Dec 11, 2008
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 69 Answers
SOURCE: F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Posted on Mar 09, 2010
Where do i buy wheels for racks on a Fisher and Paykel Nautilus Dishwasher in Ashburton NZ
Try going online to Appliance.com, I have used them in the past for hard to find parts. Good luck.
Oct 22, 2014 | Fisher and Paykel Dishwashers
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
Apr 12, 2013 | Fisher and Paykel Dishwashers
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Grandkid palyed with buttons while in a cycle now when you put it to wash it just beeps and the light turns red
might have set the child lock button. If you have the manual it explains how to disable child lock
Dec 30, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The panel cover on my fisher & paykel nautilus is broken
Fisher and paykel is based out of australia. call the # in the manual to order part. they have a division in california. parts usually take me two to three weeks to recieve.
Jun 21, 2009 | Dishwashers
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
