Question about Hisense Televison & Video
Hisense LCD Colour TV (Problem)
The Code on the Manual is LCD2629 = Bought about a month ago. Our electricity tripped and although our dvd still plays on the TV and there is power, we cannot get a picture = horizontal black lines and snow on screen. Gone thru OSD Menu and nothing seems amiss. Not sure what else to try = any suggestions ? Thanks a Lot = Karen
salt56
  • 373 Answers
SOURCE: White horizontal flickering lines
If still under warranty, take it back. but first check your cable input connections or cable signal may have went bad. Lastly it could be the signal module inside.
Posted on Jan 02, 2008
HDTV GURU
  • 261 Answers
SOURCE: Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Posted on Feb 06, 2008
melnavz
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
SOURCE: OSD locked Hisense PHD-4220
press menu, when osd locked appears press number 9 before osd locked disappears
Posted on Jan 21, 2009
premtech
  • 934 Answers
SOURCE: Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Posted on Feb 04, 2009
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
How do I play dvd's on my hisense LHDN32V66AUS 32 IN. LCD TV? I HAVE A DVD PLAYER PLUGED IN.
If it is like the model I have, you select it from the input button located on the top right of the remote. According to where it is plugged on the back of the tv, more than likely it is either the av or component input.
Jul 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Unable to play DVD's
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Mar 19, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
Dec 23, 2008 | Hisense LHD3206US Television
Hi Sense 26'' LCD2629 No Picture No Sound Just Black/White Lines
Unplug the TV to let the memory clear. Wait 1 minute, replug, see if that works.
Sep 03, 2008 | Hisense TL2620 26 in. LCD Television
Picture is blurry on new Toshiba 42HL67 lcd tv
Hi suegy, the quickest thing to test is play a dvd and observe the quality of the display. if still blurry or dull, could mean something wrong with your TV. going through what causing it...could be weak signal or CCFL lamp not glowing enough or fully.
Since its only a month ago, should be still u/warranty. Check out where you bought from and avail that warranty.
Good Luck.
Feb 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Televison & Video Logo
50 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
