Question about Cameras
Canon powershot sx200is with panasonic 4GB memory card says memory card is locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Dec 30, 2010
Why is it the camera olympus become white protected?
You may have inadvertently moved the switch on the memory card to 'Lock'
May 02, 2014 | Canon Powershot Sx200 Is Digital Camera...
My camera is canon powershot sx200is,wen i on my camera its showing as MEMORY CARD ERROR..PLZ GIVE ME A SOLUTION
Do you have another card you can try?
Also, look into the socket for the card. Are there any pins that look bent or out of place?
Jul 01, 2011 | Canon PowerShot SX130 IS Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
Canon PowerShot SD400 No memory card message, but there is a memory card installed. Tried multiple memory cards and got the same message. Made sure the memory card was locked.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you're using 4GB or larger SDHC cards, they won't work with the SD400 as that camera was made before SDHC came out. Consider 2GB or less standard SD cards only. They're very inexpensive these days on Amazon..
Dec 27, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a Canon SD400 Powershot digital camera. It
First, make sure your camera can accept SDHC cards. If the camera says the card is locked, move the slide switch on the side of the card.
Jun 13, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
I just bought a canon powershot sx200is. I
Sounds like you didn't use the "safely remove hardware" function. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...try to turn it on. Let me know.
May 09, 2010 | Cameras
4GB card incompatible?
I've come across many people who say their card isn't locked only to find that the slide switch on the side of the card is indeed in the locked position. Check yours.
Jan 15, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
I just purchased a 4gb memory card for my canon powershot sd700 and it reads memory card error-card locked. I put my old 2gb card in and it works just fine. I took the 4gb back to the store and bought...
ok, first off:
make sure the card is compatible with the camera and the camera is compatible with the card (reffer to the manuals of both products).
if all checks out, contact the manufacturer of the camera first, then do the same with the card.
if everything works up to this point, but you still cant get it to work, get a new camera.
Oct 27, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Oct 24, 2009 | Canon Cameras
Memory card is locked w. Canon Powershot SD1000
Your Sd1100 is compatible with a 4gb card, so that's not the issue. If the lock-switch is in the correct position, the only logical conclusion (which you have already come to.....good troubleshooting on your part!) is that the camera is busted. Send your two "friends" the bill. What a drag.
May 27, 2009 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
82 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
