Question about Clarion CZ209 Car CD/ MP3 Player
As the cd/usb is playing on the clarion cz209a, i have no sound and if i turn the volume up or down 'amp grd' come up on the screen. after turning the car off and on again the same thing happens. if i turn the volume up or down the numbers go up n down like normal but still no sound..
SOURCE: amp guard
Other sites I've read about this problem suggest that first you try checking the wiring to the speakers for a fault to ground OR you have speakers with too low impedance. If those check out ok, the unit needs to go back for service.
Posted on Jun 01, 2008
singh_shady
  • 45 Answers
SOURCE: Ihave power but no sound
hi bign,
try the following things:
1:Try checking your ground connections, if they are good, then try regrounding the head unit to some bare metal in the dashboard, you could have a problem with the factory ground.
2:try looking at your speaker connections, sounds you have a wire grounding,try disconnecting all speakers and see if it does it. If not, try connecting one at a time, see if you can single out the speaker thats causing the problem
and also check to make sure the speaker terminals are not touching any metal, which is unlikely, because they are factory speakers.
god luck! and please rate this solution!
Posted on Feb 13, 2009
  • 222 Answers
SOURCE: The Clarion radio in my vehicle has the word AMP
Is this a newly insalled one? check your wiring's, you may be lacking ground connection.
Posted on Jun 08, 2010
  • 454 Answers
SOURCE: it says amp guard when i turn it up
Sounds like you have speakers that are wired incorrectly. Most car stereos require a 4-ohm load, if you wire two standard speakers in parallel it will create a 2-ohm load and cause this condition.
Posted on Jun 28, 2010
  • 239 Answers
SOURCE: clarion dxz545mp amp guard
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
Posted on Aug 19, 2010
When i turn stereo on and there is no sound and AMP GRD comes up. how do i sort this out
The amp needs a ground green wire. Attach it to a metal object with a screw. The wiring harness will have a green wire sometimes with a factory installed ring on it to be able to attach it to a ground
Apr 07, 2013 | Clarion CZ109 Car CD Player
ITS SAYS AMP GRD
All you have to do is press the source button for 10 seconds till the power goes off and it only shows the time. Then turn it back on. It should be working then.
Feb 23, 2011 | Clarion DXZ275MP CD Player
It says amp guard when i turn it up
Jun 28, 2010 | Clarion DB175MP CD Player
Why does my radio say amp grd when there is no amp hooked up and it was playing just fine tell now
sounds like you need to check your speakers and/speaker wires to make sure you don't have a short to ground or bad speaker. if those check out, you may have a bad output ic inside of the deck.
May 30, 2010 | Clarion DXZ438R CD Player
Installed and no sound or nothing
Im guessing you have an amplifier if not check the cd player ground " AMP GRD" means amp ground is faulty. In the event that you do have an amplifier check that ground wire as it's most likely the problem.
Feb 25, 2009 | Clarion DB285USB Car CD/ MP3 Player
Car stereo receiver
Maybe the owners manual would help. It says you can adjust the sensitivity of the AUX input through a menu. It sounds like the AUX sensitivity is just set to max. Look for the 'to change other settings' chapter, instructions are in there.
If you don't have the manual, find it on the official website.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
The link to download it is on the upper right.
Apr 23, 2007 | Clarion DXZ555MP CD Player
Clarion CZ209 Car CD/ MP3 Player Logo
59 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
