Question about Blaupunkt Car Audio & Video
Hi. Bought a 1997 VW POLO, 2nd hand - has a Blaupunkt ACO 105 in it - screen reads code error. How can I get code number, and how do I clear code error, to enable me to input new number ? Help please!!!
MrRobertLee
  • 16 Answers
SOURCE: NO POWER / SHUDDER
Is it a standard or automatic transmission? If standard, your clutch may be slipping. While driving down a straight road, push the brake while still in gear and push the gas pedal as well. If the engine slows with the vehicle, the clutch isn't slipping. If the engine speeds up while the vehicle is slowing down, the clutch is slipping.
If it is an automatic, check the transmission fluid. You may be low and the transmission is slipping while under load, or the torque converter is slipping for the same reason. You may have a bad torque converter clutch switch, but the computer should have picked that up and made your "Check Engine" light come on.
These are the main reasons you would be losing power going up hills unless your engine isn't powerful enough to handle the larger tires on extreme hills. (It takes more power to turn a larger wheel going up hill since the vehile has to travel further for each revolution of a larger tire. Incidentally, have your speedometer checked. You will be going faster than what the speedo says since you put larger tires on.) Good Luck.
Posted on Aug 19, 2008
  • 193 Answers
SOURCE: VW Polo Dash Instrument's
buy a repair manuel from a parts store. Check to see that it has the wiring diagram in the manuel.
Posted on Nov 22, 2008
  • 14 Answers
SOURCE: vw polo car wont start
try disconecting the coolant temp sensor and then try, it may be faulty, also check the hall sender unit in the distributor, if it has one, the centre pin should be the signal wire if no pulse is present the sensor is faulty
Posted on Jan 16, 2009
SOURCE: VW Polo Classic 1997 IDLE Problems
Hello, VW polos 1.0, 1.4. 1.6, suffer from carbon bulid up in the throttle bodys causing bad idling, esp the Bosch Mono-Motronic (Throttle Body Injection systems), a good clean with carb cleaner should repair the problem, also engine temp sensor replacement and idle speed control valve replacement can help idle problems.
Posted on Apr 19, 2009
Obertelli
  • 3006 Answers
SOURCE: Hi, the rear windscreen wiper on my 2003 VW polo
The most common reason for this is a blown fuse, so using your vehicle owners book locate and check the fuse first. (if you don't have one then buy a Haynes manual for your car, the cost will pay for itself with the first repair you do). Modern automotive fuses not only have the current rating clearly marked numerically, but are colour coded and the fuses are designed so that you can easily see if they're blown when you pull them out to check. Most modern vehicle fuseboxes have a few spare fuses included and often have a small plastic tool to assist with pulling them out.
Normally a blown fuse needs further investigation as they should only fail if there's been a problem which would otherwise cause fire or other damage, but if wipers are operated inappropriately then it can cause enough load to blow the fuse. Sometimes the wiper spindles can become worn allowing water to get in and corrode the internal parts; this will cause the spindles to bind or even seize up and also cause the wiper motor to draw sufficient current to blow the fuse.
Inappropriate use includes operating the wipers when the screen is dry, trying to use them to clear snow, ice or debris, operating them if the blades or arms are damaged.
If your problem turns out to be more than a straightforward blown fuse then please add a comment to my answer and I'll try to give you more specific advice. If my answer has solved your problem then please return the favour by rating my answer.
Posted on Sep 24, 2009
Hi im looking for a Vw polo classic 1.6 1997 fuse panel diagram.
Is this how the fuse box looks?
3cc50120-3e64-4c93-b265-b1351bb80c27-fb1moghuyt5lkvoohrye4qp0-2-0.jpeg Yes? Please comment if no.
Try this link to explain the numbers
Volkswagen Polo mk3 fuse box Auto Genius
Jan 17, 2018 | Cars & Trucks
I want to fit a used ECU on my vw polo 2006. Can it work and how do I get about it? What are the risks? Thanks for your help
One of the problems you may come across fitting 2nd hand ECU is the immobiliser, your key will not be coded to the ecu that you will be fitting.
Feb 27, 2017 | Volkswagen Polo Cars & Trucks
Hi i hit my mark 3 vw golf into a ditch and now the left hand side wheel is bent and possibly the ball joint or drive shaft. Will i be able to use parts from a vw polo of similar age. Will the vw polo...
Simple answer: No. Polos and Golfs use different mechanical components.
More complicated answer: If there is that much damage then the bodyshell mountings are also quite likely to be distorted which will make any repair attempt futile. Ideally you must get the damaged parts stripped off and then get the mounting points accurately measured. This can only be done using specialised measuring equipment. The alternative is to invest in the parts needed for your repair and to fit them with an immediate alignment check at the nearest suitably equipped garage. If the alignment of the body is off then the car is effectively a write off as repairs will exceed the car value.
Oct 06, 2010 | 1997 Volkswagen Golf
HI CAN ANYONE HELP ME WITH A RADIO CODE FOR VW BEETLE 2001 BLAUPUNKT 7648229360- REGARDS GAZ
Sorry...this code will only be available from your VW Dealer or a Radio Decoding Service.
VW Blaupunkt codes are not available for free from anywhere on the Internet
Aug 22, 2010 | Volkswagen Car Audio & Video
Blaupunkt car stereo needs new code
try asking here
www.ukbookshelf.co.uk
as they offer free advice and codes , especially for these Bosch radios fitted in Suzukis
May 07, 2010 | Blaupunkt Car Audio & Video
Hi, need diagram of 1997 VW Polo diesel gearbox
Hi Paul, Most of these gearboxes were almost identical for vw during the those years, some manuals are available free from this site
http://carservicemanuals.blogspot.com/search/label/Volkswagen
Hope it will help you out.
Dave
Nov 03, 2009 | 1997 Volkswagen Golf
Need a unlock code for radio cd changer vw jetta, i have the serial no, the original vin no
i need code for radio cd blaupunkt (fiat punto cd)
bp no :7642375316
product no: 735337934
is bp code is:237534139299 my email is gujjar_pakistan_da@yahoo.com plz urgent plzzzzzzzzzzzzz
Oct 29, 2009 | Clarion Car Audio & Video
Flooded VW Polo 1997
run scanner for trouble codes, some auto parts stores will do this for free, all electrical connections should be disconnected, dried, cleaned and coated with dielectric compound, change all fluids
Sep 29, 2009 | 2007 Volkswagen Rabbit
VW Sat Nav
Double click my computer, under system tasks- click system info, Hardware tab-Click Device Manager, Sound,Video And game controllers - SigmaTel (or other) Update driver or enable.
Mar 01, 2008 | Tablets & eReaders
Car Audio & Video Logo
43 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
