Question about Honeywell Heating & Cooling
Will a th6220d1002 honeywell t-stat operate a 15ton rooftop unit?
  • 182 Answers
The Honeywell pro6000 runs on 24 volt control voltage and can control a 15 ton rtu that uses the same ac voltage in its controls.
Posted on Jul 08, 2008
Have a rheem 41-20804-15 changing it to a
Do you have it programmed right? I don't know the colors of your thermostat wires but your w2 wire will be hooked together with your emergency wire they will be on the E terminal. you hook it up the same way you took it off but hook w2 and E together on the E terminal.
Sep 04, 2014 | Heating & Cooling
Is this a thermostat problem or system failure?
it sounds like no communication from stat to board. cable connections
Jun 03, 2014 | Dometic Rooftop RV Air Conditioner
Compressor will not stop running
There has to be a stat or switch or controller of some kind on the rv. I would check that first. If you have a battery operated stat then try changing the batts, otherwise it could be the contactor on the unit or a bad stat.
Apr 26, 2012 | Dometic Rooftop RV Air Conditioner
I have an RV roof mount air conditioner that turns off and on at the unit. Can it be wired to a thermostate so it would operate automatically?
Yes - and as a matter of fact you should have a t-stat incorporated in the unit you have. It might be called 'Temperature Control' or something else - but you should have a t-stat.
Jun 13, 2011 | Dometic Rooftop RV Air Conditioner
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
Honeywell thermostat manual
The model number is going to be on the thermostat. It is not unusual for the number to be on the back of the stat, meaning you may have to take it off the wall. It could also be found betweenthe base ans the stat.
Once you have the model number googel "Honeywell XXX" with XXX being the stat model number. If you can't find the stat, you can go to the Honeywell web site and do a search, matching your stat, by the pictures and functions. It is a bit tedious, but it works.
Jul 22, 2010 | Honeywell Programmable Thermostat Heater
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Need to wire thermostat
one wire to R the other to W (or W1). Dosent matter which is which
Oct 17, 2009 | Honeywell Electronic Programmable...
Honeywell 5-2 Programmable Thermostat wont turn on
I'm assuming the screen is not blank, and that you can select heat/cool and nothing happens. If it's battery operated then there probably is an issue beyond the t-stat. Technicians normally remove the G or Y wire from the thermostat, then jumper or touch the G or Y wire to the wire that's connected to the R terminal. If the indoor or outdoor unit engages, then the t-stat is/may be the issue. Lots of help out there for testing/bypassing a thermostat. If you're t-stat is battery operated, there is probably an issue that's at the inside unit, like a low voltage short that opened the low voltage fuse, or many other reasons that would cause this scenario. I'm not sure if this will help you, bit you may need a technician if it's not the t-stat.
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
