Question about Refrigerators
Kenmore Elite Side by Side Refrigerator Water line failure
The water line going up in to the back of the refrigerator has aged and is now extremely brittle and breaks frequently. Is it practical to replace this line? How many other customers have had this issue.
  • rwtrav Jul 07, 2008
    The water line is within the walls of the refrigerator. How am I supposed to disconnect it to pull it out?
  • rwtrav Jul 08, 2008
    I thought you guys were experts. Wrong
    Genius:
  • 1,122 Answers
TURN THE WATER OFF ,PULL THE OLD HOSE OFF,TAKE A PIECE TO LOWE'S AND HAVE TMEN MATCH IT UP ,REPLACE AND YOUR DONE,LET ME KNOW-MIKE
Posted on Jul 07, 2008
  • MIKE major Jul 08, 2008
    you **** off,i said let me know!!!!!!!!!!!!!!!!
    you did'nt say it was in the wall you ***,next time explain the whole problem not just half,this is not a guessing game dude!!!!!!!!!
Icemaker and water spout in door not working
Probable inlet water solenoid valve failure. This solenoid valve is located on the back of the unit and attached to the water supply line from your house.
Jan 26, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Elite refrigerator with the freezer on the bottom. The water comes out of the water valve slowly when I want to fill up a glass. Why? It's the slowest flow of water that I've...
Restriction in the line. Check the water line to make sure it's not pinched or kinked.
Often times too the water line from the refrigerator is connected to the cold water line of the house with a self tapping valve. Turn the valve off and back on a couple times to clear any restrictions.
If everything is ok with the water line to the refrigerator then you will need to replace the water inlet valve behind the refrigerator.
Aug 03, 2011 | Kenmore Elite 78722 78729 Bottom Freezer...
Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
May 14, 2009 | GE GSS20IEP Side by Side Refrigerator
Water line to Kenmore refigerator is brown
Some tubes turn brown gradually with age. This is normal. But if yours is not made of that material (not sure what its called), then it could be that the pipe is dirty. If this be the case, it is definitely better to get the line replaced, as it is definitely a health concern. I would recommend getting a filter fitted to the line as well, just as a precaution..
Sep 29, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
I have a Kenmore model 106 9555710 SxS - no wate through door
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
Jun 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Water dispencer not working
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Remove Doors on Side by Side Kenmore Elite Refrigerator with water tube
this is the new style connectors push in on the blue end of the connector and pull on the hose it will come out of the quick connect connector
Apr 25, 2008 | Kenmore Elite 20972
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
