Air con keeps switching on and off by itself???
  • 2,133 Answers
Check, there is loose contacts in power to indoor.
Posted on Dec 30, 2010
WHRE IS THE FAN FUSEE IN A 1.3 TOYOTA TAZZ
you changed the thermo switch and relays and it didnt fix it
did you test the fan motor itself
the fuse box cover should have a fuse layout diagram
engine cooling fan
look for a 30 amp fuse
they usually near the fan relays
is the air con cooling fan working with air con on
and engine running
26238251-04wei2fenntfkeahz4fn3g0j-5-0.jpgwhre-fan-fusee-in-1-3-toyota-tazz#sln-36379873-rmi0ll110lgwm2wbdtthe4rs-3-2_0.jpg
Jul 15, 2016 | Toyota Cars & Trucks
We have a 2002 Chevy Malibu.. And the fans want run to keep the motor cool.. When the motor get too hot the car will shut off.. So, what do I do about it??
First check fuses, there are two fans if fitted with air con. The air con. fan only comes on with the air con. The engine radiator cooling fan comes on at operation tem., it is controlled by a censer switch on the radiator .If there is power to the switch and the switch is OK the fan motor is at fault.
Aug 10, 2014 | Cars & Trucks
My 2000 Toyota Echo will not let me put on air or air conditioner idles high at low speed and at park or stop?
It is normal for the idle to increase when the air con is switched on. There is a fuse in the engine compartment - I-UP (idle up)
May 05, 2014 | 2000 Toyota ECHO
Air con keeps turning its self on and off ???
Could be low on freon therefore the low pressure switch cuts it off. Once the pressures get stablize it will cut the unit back on until it goes off on low pressure switch once again
Jan 11, 2014 | Heating & Cooling
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
I dont no how to work them,ive switched it on at the wall and put both the input and output dials onto max.do they ususally take over a day to gather heat as mine had no heat in it at all lastnight.theres...
what kind of air con are we talking about. a box air con in your window ? whens the last time you have seen it heating? does it cool. it should take 1 min for the fan to start 90seconds for heat/cool air to come out
Nov 09, 2010 | Heating & Cooling
Celestial split system air conditioner
TRY TO SHUT DOWN THE BREAK AND TURN IT ON AGAIN 10 MIN LATER
Mar 08, 2009 | Heating & Cooling
I own a nissan pulsar 2001 LX & the air con swith dosn't work on 1,2,3 & on 4 the fan blows the air in full force. I'm in the process of selling & need to fix it asap & as cheap as poss. hopfully it's a...
A cheap and nasty way to make it work is to by pass pressure switch in the engine bay,your aircon has shut itself down to protect itself.the switch thats responsible for that is either on the air con compressor with two wires plugged into it or close to the reciever/drier, join the wires together and the air con switch and associated parts will work again.This is a short term fix as the switch is there to tell you that the aircon pressure is too low and ultimately it will need recharging.
Dec 28, 2008 | Nissan Pulsar Cars & Trucks
Air con coming on
I Have encounterd this problem and the problem i  troubleshooted it down to was a defective switch
Oct 03, 2007 | Carrier 52CE-307-3 Air Conditioner
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
