Question about DBX 1231 Home Equalizer
My setegraphic equalizer Panasonic SH-D5 have damaged transformer please help me information transfromer for this tool. nguyennhuy210@yahoo.com
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
I need a manual for TECHNICS SH-GE70
You can download a copy from Panasonic here.
Dec 29, 2010 | Technics SH-GE70 Home Equalizer
I bought SH-GE90 DSP And I pluged into 240V source while the indicator was on 110v and now its not working will replaceing the transformer will help or it just simply gone.
It is not possible for us to be able to determine the extent of the damage. It is possible that only the fuse has been damaged. It is also possible that the rectifiers have been dmaged. The bottom line here is that there needs to be some examination of the unit and some testing of the internal components. The best case will use parts in the $5 range. Worst case you are looking at $50 or more in parts. If the cost is not too high, take this to a servicer and ask for a detailed repair estimate.
Dan
Dec 02, 2010 | Technics SH-GE90 Home Equalizer
The dislay flickers SH GE90.technics .it seems to be a common fault.. can this be fixed
replace the 3 electrolytic capacitors in the power supply section near where the lead from the transformer connects to.
they're sat side by side.
you may notice only 1 might be leaky but replace all 3 for good measure.
i've had quite a few with exactly the same fault and all were cured by replacing the above.
hope this helps?
Mar 11, 2010 | Technics SH-GE90 Home Equalizer
Will not power up
Before we can help you we need as much information as possible about what happened the last time you used the equalizer, have you had any storms lately? when you last turned the equalizer on did you hear it go bang?
Please provide as much information as possible.
Regards.
Aug 26, 2009 | Technics SH-GE70 Home Equalizer
User-manual Technics SH-GE70
Download instruction manual of SH-GE70 from Panasonic Support but you need to pay little fee to Panasonic.
Jan 04, 2009 | Audio Players & Recorders
USER MANUAL NEEDED
Hi - You can download the manual from the link underlined in blue below:
SH-GE90
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Technics SH-GE90 Home Equalizer
Technics eq sh-ge70
According to Panasonic the manual is only available for purchase (paper/CD-ROM) 1-800-332-5368
Jun 06, 2007 | Technics SH-GE70 Home Equalizer
DBX 1231 Home Equalizer Logo
142 people viewed this question
Top DBX Audio Players & Recorders Experts
Philip Rowney
Philip Rowney
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
