Question about Lexmark X4270 All-In-One InkJet Printer
Printer not working.. my pc recongizes the printer.... printer just wont print..... it will only print test sheets
    Problem Solver:
  • 18 Answers
First, I would check to see that the USB or serial connector is installed properly from the printer to the PC. If that is good, then I would make sure to install the printer driver and the printer software from the Lexmark CD. You can use the Lexmark Solution Center to trouble shoot further (this is the software that comes with the printer).
Hope this helps.
Posted on Dec 30, 2010
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
Printer is paused wont restart
it may be that you have a corrupt file in the print queue, a quick fix is possible - switch the power socket OFF, disconnect the PC/Network connections.
power on the printer, it should have had time to clear the memory now, see if the machine is able to print a menu page or config sheet ( open menu enter the information menu- print config sheet:)
if the printeris able to do thiswith no network connections you have eliminated the printer from the problem. next switch on and log into your PC, still disconnected from printer, open print queue and delete all documents from the queue ( your not deleting the files ( just the print requests)) once this is done then reconnect the printer and send first a windows test page ( confirm working connections first ) then attempt to print the failed file - if it fails in the same manner - the file was your problem.
Mar 16, 2014 | HP OfficeJet V40xi InkJet Printer
My HP PSC 1315 printer/scanner prints the test page every time I turn it on. A 2008 post from littlebluemuffi helped until now, but today it still printed the test pages.
This usually happens if the printer is not aligned properly. When you replace the cartridges, it prints a colorful sheet of paper. You need to place the paper face down on scanner glass and press OK button.
This completes alignment and the printer wont print test page again.
Regards,
Sean
Feb 25, 2013 | HP Office Equipment & Supplies
I had a paper jam that i had to open up the top and pull out the paper. Now, it wont print anymore. i was able to do a test print and a sheet with some colored stuff came out, but we still cant print or...
On the desktop of your computer, find the printer icon to the far left for a Mac and at the bottom right for a PC, click on it and then find the 'print job' that is first in line to print, click ONE time on it and then click 'cancel print' or 'delete'. This should clear the computer for the printer to go back to work.... Please let me know if you need more help..... Guy
Sep 23, 2010 | Office Equipment & Supplies
After a stuck document in the printer (HP Photosmat all in one C309 series, it doesn't seem to recongize we have cleared the jam and it will now ONLY print if we use the sheet feeder.
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 31, 2010 | Computers & Internet
My printer wnt work i boght new ink but it wont print
Hi
whenever you put new ink cartridges,your printer prints an alignment sheet
if your printer isn't printing,
one of the concern could be that it didn't print the alignment,uninstall the cartridges and put them back again.
also try printing an alignment sheet using the printer driver located in the control panel,printers and faxes
once you go into the properties and click on the device settings and click on service this device you will get option to print alignment sheet
this should work
Jul 17, 2009 | Dell 926 All-In-One InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
