Question about Nerf Secret Strike As 1
I bought a Nerf SS AS-1 and when i pump it instead of storing the air for firing, it leaks it and pops out the dart.
5 Suggested Answers
SOURCE: Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Posted on Feb 25, 2010
David C L
  • 11 Answers
SOURCE: How many and what type
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Posted on Feb 27, 2011
David C L
  • 11 Answers
SOURCE: I just got my new
There are multiple factors in the inconsistency of your product's functioning.
1.) You have not successfully screwed in the battery cartridge tight enough so as the metal conductors are touching (with pressure).
2.) Your batteries are dead or almost dead.
3.) You put 4 bullets in your clip - kidding :)
4.) The circuitry may not be high quality, was your gun tampered with or from an unreliable source?
5.) Your jam door may not be high quality and could often slip from its locking point, I'd suggest taping it momentarily to keep pressure on it just to see if this is the case.
6.) The clip may be loosely in also, I'd also look into that.
If your gun stopped working permanently- I'd suggest looking inside at the white plunger, and the parts that release it from its pressurized position. There are many diagrams on the internet of the internals for it.
Email me a dluzzio@gmail.com for more info.
Posted on Feb 28, 2011
lordlangford
  • 11 Answers
SOURCE: i bout a secret strike as1 nerf gun but it never work
The gun will work but don't be scared to pump it with a deal of force I found I had this issue also untill I fully pulled and plunged the plunger with a bit more vigor
Posted on Jun 16, 2011
Is there somewhere that I can get packages of new darts?
You should be able to find refill packages at Toys R Us, but if not Amazon sells packages of various sizes.
Dec 22, 2013 | Toys
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Two solutions-
That's all!!!
LOL just kidding!!!
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
I just got my new nerf stampede and put batteries in. I turn it on it fires 4 darts and then just stops. there is no sign of jamming
Feb 10, 2011 | Hasbro Nerf N-Strike Stampede ECS Blaster
I **** it back and then hit the trigger and it won't fire... it rotates the barrel and after about a minute or so of pulling the trigger rapidly it will fire. i want to be able to shoot normally and i did...
The factory must have left out a certain spring I could only explain to you if you've modded it.
Well, I'm going to explain anyway-
When you pull the trigger there is a mechanism is triggers that releases the plunger system, therefore compressing the air and firing the dart out of the turret. The factory (as I said before) left out the spring that makes the part move up or down as the trigger is operated, therefore making the gun malfunction.
My best suggestion- get a spring and add it in (if this is the case). Open up the shells/casing of the gun by unscrewing it apart and find the orange part next to the trigger.
Please email me at dluzzio@gmail.com a picture of the inside of your gun so I can analyze it.
If all else fails, take it back to the store.
Dec 30, 2010 | Nerf Maverick Blaster
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Nerf Secret Strike As 1 Logo
539 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Nerf Toy Expert? Answer questions, earn points and help others
