Question about Intel DG31PR Motherboard
While switch on pc the fan have been working and i dont get any beep sound but the problem is system doesnt booting it shows intel screen and also keyboard doent working .....can u pls any one suggest to assist this problem (intel mother board DG31PR (B)
  • Intel Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
as for the keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Posted on Dec 30, 2010
No bios booting on start up
The model number you provided is incorrect.
It is most likely, D945GCNL. Intel site for your MB; http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
If you’re currently using 2 DIMMs of memory remove one DIMM. Open your manual to page 11. First remove DIMM "L". Attempt booting your system. Listen for possible bios beeps. Than shut the system down and remove the memory from " K " and insert your second memory DIMM. Again, boot system and listen for bios beeps. Intel suggest when installing memory on to the D945GCNL motherboard that it be done in a specific manner. See, 1.4 System Memory Page 16, in the TechProdSpec.pdf manual provided below; http://downloadmirror.intel.com/15115/eng/D945GCNL_TechProdSpec.pdf
The power supply currently in your system with does not provide enough wattage for your motherboard. To help find how much power you do need open the next link provided; http://www.journeysystems.com/?power_supply_calculator
It’s better to have more wattage power than you need. Even though you have an Intel manual for your board it’s suggested you download it from Intel. You'll need Adobe reader to view the manual. With Adobe you can use the zoom in feature. The next pdf link is your manual;
http://downloadmirror.intel.com/15115/eng/D945GCNL_ProductGuide02_English.pdf
I do not think there is anything wrong with you bios or your system memory. I think your system is under powered.
Happy holidays!
Mike
Dec 20, 2009 | Intel Motherboard
I have an hp dv2000 and when i try and turn it on you here the fan start and what sounds like maybe the hard drive booting and then nothin but the fan. The screen will not even turn on and i know that...
SOUNDS LIKE YOURE VIDEO CARD IS UNSEATED AS YOU DONT EVEN GET AN ERROR ON SCREEN TRY REMOVE AND REFIT IF YOU HAVE ONBOARD VGA REMOVE VIDEO CARD TO SEE IF IT WILL BOOT IF THIS DOESNT WORK REMOVE CMOS BATTERY AND TRY AGAIN.
Aug 09, 2009 | HP Pavilion dv2000 Series Laptop Full...
Sytem wont boot
This time your system is very ok... theres a possible reason why its automatically on without pressing the button and cannot see a device even hard disk...
Here is a tip:
1. Check the CMOS Battery maybe its weak, or try to change it a new one, and
2. Change also your power supply it might the current flow of electricity are not normal... i know its ridiculous but i experience just like yours...
Jun 20, 2009 | Intel Pentium 4 2.8Ghz System PC Desktop
Will not power up, no lights or sound
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
May 29, 2009 | Intel Everex LM7WE Notebook
Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Apr 20, 2009 | Computers & Internet
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
PC not booting
First replace its CMOS battery.
Apr 03, 2009 | Intel D845PEBT2 Motherboard
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Acer TravelMate 4150LCi
beep sound can causes from Keyboard
boot menu shown can cause from HDD
MB can cause both -> I/O (Input/Output) controller problem
Try to plug other HDD into u're laptop, if detected the problem is from HDD but if it's not it from MB
Dec 12, 2007 | Acer TravelMate 4150LCi Notebook
Intel DG31PR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
