Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Reciever for bulb is gone - Mitsubishi WD-52725 52". Rear Projection HDTV
  • 1 more comment
  • jwparcher Dec 30, 2010
    the reciever that the bulb fits into is no longer sticking out for the bulb fittings to insert into, I cant see them anywher in the cavaty, they did not come out with the old bolb
    the two prongs that the bulb connection goes into are gone!! however I cannot see them anywhere in the cavity , can you gert to the back , doesnt look like there is a removable panel there.
  • jwparcher Jan 02, 2011
    the sockets, or fittings are ok on the replacement , the "sockets that are gone are the two that the bulb plugs into, cant see them inside , should I try to take the back off/ to get at it. JW
  • Mitsubishi Master
  • 11,800 Answers
In that case the housing is defective and you must buy a full set - bulb AND housing . Here it is
http://electrified.com/Catalog/Items/?CampaignID=Nextag&ItemID=30555
Posted on Dec 30, 2010
    President:
  • 2,246 Answers
Change your tv board
  • Lastoni Wibowo Dec 30, 2010
    change your tv mainboard
  • Lastoni Wibowo Jan 06, 2011
    change your tv board
My ls2160 suddenly not working and the bulb shows dark and its fuse gone.
sounds like a short if the bulb has gone dark and the duse has gone simultaneously, I would have a technician check it...replace fuse and bulb but there might well be more to it
Jun 08, 2016 | Cars & Trucks
I have a 29ltd classic...no transmitt that i know of, recieves but is weird soundin, like people are underwater...recieves on PA, or CB..and channel 19 comes thru on all channels..??? could it be just the...
Sounds like the mixer crystal has gone bad, or the VCO is out of whack, and the radio needs to be aligned.
worst case scenario is that the PLL has gone bad. In which case the radio will need to be fully aligned after replacing.
Nov 14, 2010 | Cobra 29 LTD CB Radio
A light bulb in my ceiling fan burned out the other night when I turned it on with the remote. I changed the bulb, but since then the remote will not turn the light on or off. The wall switch will, and...
Sometimes all you need to do is switch the wall switch on and, off a few times while you press the lamp button (off press the button then: on press the button) no go? then: check or, replace the hand remote nine volt battery. still no go? then:
Check the wattage of the replacement bulb; some high wattage bulbs will rob power from the remote unit. didn't work? OK,
next turn off the power to the lamp and, open the lamp cover: you will see a large plastic rectangular box (the reciever) open the cover on the box and, you will see a block of tiny switches then: open the hand remote battery case it too will have a block of tiny switches these must match i.e. 1,3,5,= on 2, 4, = off both the remote and, reciever box. Barring that ...you'll need a new reciever for your fan.
Jun 01, 2010 | Hunter 27187 Remote Control
Display bulbs gone on my magnum deltaforce
Yes! The faceplate will need to be unscrewed from the chasis to do it.
It isn't too tough to do with good eyesight, soldering skills, and a steady hand.
Apr 09, 2010 | Magnum OmegaForce S45 CB Radio
My back light and indicators have just gone , but my headlamp is ok, dt125r 03 any ideas
The bulb has gone ,it must be change,an easy to be sure if it it only the bulb,just take out the back light bulb,see in the bulb if the filament has gone.
Jan 06, 2010 | 2004 Yamaha DT 125 R
I need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
2002grand am daytime running lights
99 - 04 grand am.
I had the "service vehicle soon" light come twice with in 1 year. First the heald light bulbs were gone. Replaced the head light bulbs and after 2 starts the "service vehicle soon" light was gone.
The second time the DRL - #194 amber bulbs were gone. Replaced these and the "service vehicle soon" light was gone after 2 starts. The DRLs are housed in the headlamp housing, the tiny bulbs beside the head light.
Sep 06, 2008 | 2002 Pontiac Grand Am
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Jun 20, 2008 | Televison & Video
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
