Question about Grundfos Comfort System Recirculator 595916
I have a Grundfos Comfort System. At the tap farthest from the hot water tank, I get a tremendous amount of grainy residue from the tap. No other taps have the residu. I've replaced teh water softener, the hot water tank and I added a whole house cartidge water filter. The only thing left is the Grundfos system. Any ideas? .
Sounds like you have sediment built up in the pipes, and maybe the furthest faucet is the gathering place.
Take off each shut-off valve at furthest faucet and connect a water hose that flows into nearby toilet bowl.
You can buy garden-hose-to-1/2-pipe adapter at hardware.
Open water so it flushes the line into toilet bowl.
Then clean out valves and reassemble shut-offs and grundfos connection.
Remove faucet aerator and flush line up to faucet.
Install new aerator.
Posted on Dec 30, 2010
Can I clean the valve to remove sediment?
when this problem presents I consider that the problem is in the weak tap stopper /seat
they can break down ,become enlarged and not move of the tap seat to allow full flow
that is the first check I would be doing
Mar 02, 2015 | Grundfos Pumps Grundfos Comfort System...
Cold water from tap is not cold
With circulating system, you wait for cold water to arrive instead of wait for hot to arrive
Turn pump off when you want cold water
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Gene
Nov 10, 2013 | Grundfos Comfort System Recirculator ...
After installing the thermo bypass valve on the furthest sink faucet from the water heater, the sink faucet has no pressure, and there is hot water slowly comling out of the cold water valve.
It sounds like the installation loosened sediment inside pipe.
Remove sink aerator and see if you can flush open the faucet.
Also check if other faucets are receiving hot water from hot-and-cold taps that says if grundfos is pumping hot water from the water heater correctly.
When recirculation pump is running, both hot and cold water lines have hot water.
If other faucets have hot water in both lines, then that tells you the blockage is localized in furthest faucet supply lines.
You may have to dissemble those supply lines and flush the sediment out.
Dec 30, 2010 | Grundfos Comfort System Recirculator ...
My Grundfos Comfort System is not working. I has been installed correctly....the pump is running, I checked and replaced the valve....still no immediate hot water. The installation instructions...
Turn on the hot water at the farthest faucet from the water heater. Once hot water is at that sink immediately go check other taps in the home. If you have to wait more then 10 seconds for hot water at other taps then you have a branched system.
Sep 01, 2010 | Grundfos Comfort System Recirculator ...
Pump gets very hot. Water not
That would be my guess. If water is not circulating then that points to impeller problem
May 10, 2010 | Grundfos Comfort System Recirculator ...
Now I have to wait for cold water at my taps
Yep! That is the problem with this type system!
To fix the problem run a third pipe from where the pump is back to tee into the cold input of the HW tank. Insulate this third line.
It will be more efficient as well.
Nov 29, 2009 | Grundfos Comfort System Recirculator ...
Grundfos Comfort System Recirculator  595916 Logo
238 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Mike Magnay
Mike Magnay
Stephen Woodthorpe
Stephen Woodthorpe
Level 1 Expert
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
