Question about Whirlpool Dryers
Whirlpool model LGB6000KQ1 electric dryer. I have to run the dryer two to three times before the clothes dry. There is a little heat, and I cleaned all the vents. Do I need a new heating element?
  • 784 Answers
If the exhaust hose is clear of debris and you feel a good flow of air through it then ' Yes ' I would say that the heating element is bad.
c...
Posted on Dec 30, 2010
I recently had the heating element replaced on my whirlpool electric dryer model #LE5800XSW3. Prior to replacement, clothes dried completely in one cycle. After replacement the clothes take at least two...
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Jan 22, 2011 | Whirlpool Dryers
I have a whirlpool duet dryer bought it in 2003 from best buy. just recently clothes are not drying completely before shutting off. i hear the gas kick on the heat ..i've stopped it to make sure the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 13, 2010 | Dryers
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Have duet electric dryer model #9200Lw1 dries slowly
are you overloading the dryer, too many clothes would take longer to dry
Feb 03, 2018 | Whirlpool Dryers
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
