Question about Nikon Coolpix S3000 Digital Camera
My Nikon coolpix s3000 won't turn on or charge. help!!!
  • 11967 Answers
SOURCE: Why can't I connect my Coolpix s3000 to my Vista
Try using a separate card reader to download your pics.
Posted on Jul 25, 2010
  • 11967 Answers
SOURCE: My Nikon Coolpix S3000 has
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 07, 2010
  • 102366 Answers
SOURCE: Hi My digital camera the Nikon
Not all computer USB ports put out enough current to charge batteries, especially if you're going through a hub. Try a different USB port if one is available. Otherwise, plug the supplied AC charger into a wall outlet and use that.
Posted on Dec 08, 2010
  • 88 Answers
SOURCE: how do you charge a nikon coolpix s3000?
It comes with a wall jack that powers the included USB cable. Plug the USB cable into the wall jack and into the camera to charge. You can also charge from a PC if you connect the USB cable to the PC instead of the wall jack.
Posted on Jan 04, 2011
  • 6771 Answers
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Posted on Jan 14, 2011
My nikon coolpix s3000 does not charge, the light only blinks for a few seconds
The battery is used byond limit. give the battery for a boosting(little higher voltage charging). after that it will charge normally.
Mar 15, 2013 | Nikon Coolpix S3000 Digital Camera
WHY MY NIKON COOLPIX S3000 FLASH NOT WORKING?
okay let mi think....
you cant charge a nikon camera via usb port the usb port is data only
please reply and try to use a nikon coolpix s3000 charger
Feb 22, 2013 | Nikon Coolpix S3000 Digital Camera
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Nikon S3000 dosent turn on
Have you updated the firmware? According to Nikon, when the Rechargeable Li-ion Battery EN-EL10 is inserted in the camera and charged, charging sometimes did not stop after the designated amount of time had passed. Usually, you'll receive the message "Battery Exhausted" if this is the problem... but you could also have a completely dead camera as well.
See Nikon's website, download updated firmware to your camera and install a NEW battery. http://support.nikonusa.com/app/answers/detail/a_id/16873
Nov 29, 2011 | Nikon Coolpix S3000 Digital Camera
When I connect the Coolpix S3000 to the computer to transfer pictures, it turns off and won't turn on
I've had some S3000's become gimmicy when connecting to a computer. The easiest way I've found to get photos off of the camera is to use a card reader connected to your computers USB.
May 11, 2011 | Nikon Coolpix S3000 Digital Camera
How do you charge a nikon coolpix s3000?
Dec 26, 2010 | Nikon Coolpix S3000 Digital Camera
My nikon coolpix s3000 wont turn on or charge there is no light coming on either i haveonly had it for a year
Mine did the same, it said battery exhausted and turened off, but before it did this it wouldnt charge I had it on the charger and nothing and then it did what I said at the beggining, battery exhausted please help I have had if for about less than a year and bad thing I dont have the recipt or waranty paper, itbis in good conditions tho.
Dec 14, 2010 | Nikon Coolpix S3000 Digital Camera
Hi My digital camera the Nikon coolpix s3000 kept flashing batter exhausted but it wont charge by the computer. How do i fix or charge my camera?
Dec 08, 2010 | Nikon Coolpix S3000 Digital Camera
My Nikon Coolpix S3000 will not take a charge. It
You shouldn't have to try to fix a new camera. Take advantage of the warranty.
Jun 07, 2010 | Nikon Coolpix S3000 Digital Camera
Nikon Coolpix S3000 Digital Camera Logo
4,427 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
