Question about Fujitsu Heating & Cooling
No cold air - Fujitsu Heating & Cooling
  • 2,133 Answers
Check temp setting minimum 3 degree less than room temp and mode in " Cool" . If no cool check compressor is working or not.
Posted on Dec 30, 2010
What does the air take hose function
Air Bypass Valve: Honda Projects - YouTube
9k=? 6:00 https://www.youtube.com/watch?v=KCJpBzxKWx4 Jul 7, 2013 - Uploaded by Nick Describing the needs and uses for a Air Bypass Valve. ... Does it really work tho. Read more ... Do Cold Air ...
Cold Air intake + Bypass Valve. ? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid... Oct 19, 2008 - Update: where does the Bypass valve go on the cold air intake? ... you encounter deep water you will know what your maximum allowable ...
cold air bypass valve..does it really worK? - Honda-Tech
honda-tech.com/.../cold-air-bypass-valve-does-really-work-404719/ They do NOT magically separate water from air, if that was what your were thinking ... which cold air intake would u guys recommend? r there any that offer some ...
Dec 28, 2015 | Cars & Trucks
Air intake bypass hose
honda-tech.com/.../cold-air-bypass-valve-does-really-work-404719/ They do NOT magically seperate water from air, if that was what your were thinking ... which cold air intake would u guys recommend? r there any that offer some ...
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
The system does not blow cold air. The liquid line near the furnace does not gets real cold (mildly cold only)
The liquid line will not be cold, but the suction line should be getting cold...sounds like you may have a leak...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
May 12, 2011 | Carrier 38CKC024 Air Conditioner
Cold air from ceiling vents when furnace kicks on. Can blower fan setting be retarded to avoid this cold air? There also seems to be a cold air downdraft from the cold air return in the ceiling. Is...
1. You can't change the blower timing at the beginning of the cycle (important to keep the heat exchanger temperature correct).
2. The issue isn't that cold air is going through the furnace itself, it's cold air in the ductwork.
3. It's likely that the cold air you feel from the return and the cold air in the ductwork are related in this way: many duct systems are imperfectly sealed and not that well insulated.
A home energy contractor (weatherization or energy auditor) might be your best resource to seal the ductwork and add insulation.
If this is the problem, then the good news is, your comfort issue can be solved and it will also save you lots of fuel, paying for the work to seal and insulate in very short order!
Dec 16, 2010 | Goodman Heating & Cooling
Nissan xterra..2000
your air con needs re gasing
Jul 07, 2009 | 2000 Nissan Xterra
Heating & Cooling Logo
46 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
