Question about Garden
Inquire if i can fit a grass catcher it is a mulcher mower
grantg1983
  • 218 Answers
SOURCE: how does the grass catcher attach to the L100 ride
sorry i cant tell you i dont know. you have posted this in the computer part of fixya please replace it in the relavent area if this answer helps please rate it
Posted on May 15, 2010
  • 3 Answers
SOURCE: 21 inch craftsman mulcher mower, if it does not ha...
yes,the magneto on the flywheel will create the energy to make voltage for spark
Posted on May 31, 2010
rycgl
  • 1545 Answers
SOURCE: mower is not shooting the
Maybe the grass you are trying to MUCLH is a little too high. Mulching doesn;t really cause the machine to "shoot" out the grass the way conventional cutting with a conventional blade does....it is the type of blade that when spinning, creates air pockets under the deck that allow the blades to keep cutting the grass over and over. Switch to a different blade to get it to shoot out.
Posted on Aug 13, 2010
Testimonial: "Thank you for your help. Should the grass not fall on the lawn after it is mulched, not stick in the deck so that you have to stop and clean it out."
rycgl
  • 1545 Answers
SOURCE: Toro GTS 6.75 mower -
Change the blade from the mulching blade to a conventional discharge blade. They are quite different in design. Also, a cover plate on the deck will have to be removed in order for the new blade to work (plus the grass has to discharge somewhere,,,eg ,,,side or back.
Posted on Sep 14, 2010
  • 40 Answers
SOURCE: Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Posted on Jun 16, 2012
Looking for catcher to fit
Instead suggest a mulching blade.
Check to see that the earthworm population in your lawn is healthy.
They will eat the clippings and create castings fertilizer for your lawn.
Most earthworms come out at midnight to feed.
Feb 17, 2016 | Garden
How do I attach the grass catcher to my push mower?
model number and photos of what you got now????
Jul 02, 2015 | Garden
Grass catcher doesn't fit
Do you a plate to attack to back of tractor with 4 bolts.
Feb 04, 2014 | Husqvarna Tractor Bagger
Grass catcher
What I would do Wayne is contact Ariens through the web site or at their dealership and see if one may be placed on your mower. Each manufacturer has their own set up for grass catchers, so I have not seen one the fits all. If you don't get anywhere Wayne, think about buying a lawn sweeper that is attached the the rear of you mower. If you purchase a good one, you will be very happy with it's performance. I hope that helps you out in some manner.
Jun 18, 2013 | Ariens 42" Riding Lawn Mower Blade ...
How to engage grass catcher on toro 22
Lift rear door, catcher bag has a hook on each side that must be hooked over bar on each end.
Jun 17, 2012 | Toro Garden
Jun 16, 2012 | Mtd Garden
Toro GTS 6.75 mower - how do you get the grass to go into the catcher instead of the mulcher?
Sep 14, 2010 | Garden
Rear mounting grass catcher has space along bottom where all the grass gets out. Yes the side shooter is closed. Yes the top door over the catcher is closed. Yes, it's hooked onto the only place I can...
grass will build up over time on the underside of the deck possibly impairing the flow of the clippings. I use a flat screwdriver to scrape the big clumps of grass off the underside.
Jun 13, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
