I see only green led on the front panel I can turn on - off, but high power is dead... thanks
  • 4,889 Answers
Please tell me whats the make and model of the set so that I can help you with the diagnosis.
Sai.
Posted on Dec 30, 2010
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Hitachi hd1080
Model? what if any lights on front of set come on? If total dead unplug and look for fuse connected where power cord enters set, as much as I can suggest without more info.
Jul 20, 2013 | Televison & Video
The red led on the front of the unit flashes. unit will not turn on and led doesn't turn green. is this a power supply issue?
The power supply board of the Television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 06, 2011 | Akai LCT3201AD 32 in. LCD Television
My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jan 13, 2011 | Televison & Video
Flashing red led.
This is a very common problems with LCD and Plasma tvs.The power supply board have dead leakagas capacitors.These dead capacitors they alway bulges up on it tops or puff up on it tops.U know basic electonic's and soldering take the tv aparts searches all around the power supply board,that the board where the power a/c cord conected to it.Replaced these dead leakages capacitors,ur tv will power up again and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40V3000 Television
Mitsubishi wd 65735 - blinking green LED on front panel, TV won't turn on
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck..
May 25, 2010 | Mitsubishi WD-65735 Television
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
Pana TH-52PWD8UK. No picture, flashing red LED on front panel
Thanks for the quick answer. I purchased the set in 2005 and it lives outside under an overhang on my patio in humid South Florida. Unfortunately, I couldnt count the red flashes before it went completely dead. Think it was 4or 5. This would correspond with a possible fuse failure on the Power supply. I bought the online service manual, I just wish I knew what to do with it!! The fuses both seem to check out ok on a continuity check. any ideas? Thanks, Charlie
Dec 05, 2009 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Dell Dimenion 3000
sounds like you need a new motherboard. Try to reset the bios with the jumper (or remove the battery and unplug it) and see if that does anything, if it doesn't start looking for a new mb.
Jun 04, 2008 | Dell (E210882) Motherboard
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
