Question about Canon PC-795 Copier
My copier does not turn on
However it turns on sometimes and if i switch it off it will not turn on again.
For the last couple of weeks i was hearing weird sounds like the printer turning on and off by itself periodically
    Sergeant:
  • 329 Answers
Sounds like a bad on off switch, some times jiggle the switch to see if it comes on, if it flickers yes switch is bad. Could also be Power supply or possible even power cord...
Posted on Jul 09, 2008
2000 pontiac grand am stalls
The pump should run quietly. Do you hear a load hum while driving? When it stalls, with the key on and everything quiet in the car you should hear a faint hum when you turn just the key on ( not cranking the engine over ) this last only a few seconds. If you hear that. The pump is working you might have another problem. Let me know
Dec 27, 2013 | 2001 Pontiac Grand Am SE
Ignigtion sometimes wont start
sounds like a problem with the ignition control switch. get it check out by a mechanic .
Nov 11, 2013 | 2003 Ford Taurus
Light turns on by itself
Sometimes they just need to be reset
1 turn off power to switch (Circuit Breaker off)
2 wait 30 seconds
3 re - turn on power to switch again (Circuit Breaker on)
4 wait for lights to turn on by themselves ( about 15 seconds after power is turned back on)
should be OK after this remember to not enter the beam after power is turned on ...... (see #4 above) as this would make switch beam super sensitive. Hope this helps
Apr 01, 2013 | Leviton ODS10-ID Decora Wall Switch...
I bought samsung s3650 mobile last week and its touch screen is unresponsive or sluggish sometime and it works find sometime. why this problem with touch screen
TRY CLEARING THINGS U DONT NEED FROM PHONE.ALSO TURN OFF PHONE TAKE BATTERY OUT FOR A COUPLE MINS THEN START UP AGAIN. SEE IF THAT HELPS? GOOD LUCK!
Mar 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Ignition turns over but car will not start...
sorry to hear your vehicle is down. check the fuel filter if so equipped, or could be fuel pump.
hope this helps. have a good day
Jan 29, 2010 | 1992 Isuzu Rodeo
I have a 2001 Grand Caravan Sport. Not starting
THER ARETWO COPPER CONACTS IN THE STARTER SOLENOID THAT ARE REPACABLE.IF YOU TAKE THE COVER OFF THE SOLENOID PART OF THE STARTER AND PULL OUT THE PLUNGER I THINK YOU WILL SEE THAT ONE OF THE CONTACTS IS BURNT SHORTER THAN THE OTHER CAUSING YOU TO JUST HEAR A CLICK WHEN YOU TURN THE KET TO START.ANY STARTER REPAIR SHOP SHOULD STOCK THESE PARTS FOR BETWEEN $10 & $20 .
Oct 02, 2009 | 1994 Dodge Caravan
Turn signals work intermittantly
multifunction switch? I think so.
Jan 29, 2009 | 1999 Ford Explorer
My printer is not responding when I switch it on.
Hello
I just held the button down for a lot longer. Have not switched it off again though!.
Joan
Jul 21, 2008 | HP DeskJet F380 All-In-One Printer
Tv switches off
set goes on 20 seconds it goes off
Feb 24, 2008 | RCA TruFlat 27F520T 27" TV
Printer not receiving jobs
Hi Mark, first of all,You need to check ports on Your PC ,if this printer is networked.Second, try to set sleep or Energy saver mode on printer to highest possible time.To do that,just press "Menu" key on printer control panel and go through menu to find sleep mode.And maybe best solution is to upgrade firmware on your respectable machine.For that, You need :Compact Flash card type 1,Card reader,and firmware.Obtain or download firmware files or informations about that from Kyocera web site or from Kyocera service partner in Your country. Copy unzipped files to CF card(you need to format CF card on printer -Read user manual )Switch off printer.Push card in CF Card Slot in printer.switch on printer and wait till all light flashing on printer control panel.Switch off printer and remove CF card.You can contact me if you have any problems about that machine.BR
Nov 28, 2007 | Office Equipment & Supplies
Canon PC-795 Copier Logo
old marine
old marine
Corne Viljoen
