Question about FXsound iDFX Audio Enhancer for iPod
Try to install idfx 1.1 for itunes but an error keeps coming up saying 'itunes is not installed' but it is installed!!!! HELP! Thanks
I cant open itunes, it just shows an error, it says to uinstall itunes, and install it again, but when i try to uinstall it, it wont work either. and install it again doesn't work. the error says:...
Try to reboot your PC then try uninstalling it again!! If you still have no luck try using this software program it has worked for everyone I know who tried it on similar problems exept 1 and had had other underlying problems so hopfully you do not.
http://www.error-expert.com/uninstall_any_software.html?gclid=CJONxuS-takCFYZ75Qod2woukA
Thumbs up if this help and feedback is appreciated!!!
Good Luck!!!
Jun 14, 2011 | Computers & Internet
I have a new dell laptop with vista and cannot install itunes - it freezes and comes up with an error message.
What does the error message say? Post the exact contents here.
Just in case, check to see if your computer is 32-bit or 64-bit by going to computer properties. Make sure you got the correct version of iTunes for your computer.
Check this Apple support page for more information.
May 05, 2011 | Apple iTunes
When trying to download itunes keep getting a report that says ''windows installer encountered errors and can not configure itunes.'' I am using a 64 bit PC with Windows Vista Home Premium. Thanks.
It means that the installer you downloaded is not compatible with the version of Windows you're trying to install it to. Make sure to visit iTunes.com and select the right installer for it to work.
Feb 19, 2011 | Apple iTunes
After installing , when trying to run itunes , it says apple application support is required to run i tunes, please uninstall and imnstall again , i have done what it says. and still the same error comes...
1. Download and install WinRAR.
2. Right-click the iTunesSetup.exe icon and choose "Open with WinRAR".
3. Once the EXE is opened in WinRAR, double-click AppleApplicationSupport.msi and when the installer window is open choose "Repair".
4. Done! You can now run iTunes normally.
Crat
Oct 25, 2009 | Apple iTunes
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
Error code 2329
It's a error message with Windows installer not for Itune.
Try to get latest windows installer from link below
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482FC-5F56-4A38-B838-DE776FD4138C&displaylang=en
Supported Operating Systems: Windows 2000 Service Pack 3; Windows 2000 Service Pack 4; Windows Server 2003; Windows XP; Windows XP Service Pack 1; Windows XP Service Pack 2
Dec 28, 2008 | Computers & Internet
Itune update and now it won't even open
try to uninstall the the latest version of itunes on your pc and then go back to what the version you are using. After that, update your old itunes, not install your latest version.
May 13, 2008 | Apple iPod MA446LL/A MP3 Player
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Itunes software erros
error keeps saying unable to find disk?
Oct 24, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Computers & Internet Logo
148 people viewed this question
Top FXsound Computers & Internet Experts
David Payne
David Payne
Are you a FXsound Computer and Internet Expert? Answer questions, earn points and help others
