Question about HP Designjet T1100ps Printer
I have Hp Desigejet T1100ps and its showing the error code of 47:01
    President:
  • HP Master
  • 2,246 Answers
Description:
Star wheels motor error..
Corrective Action: Try the following:
???? Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
???? Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
???? Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
???? Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
???? Replace the Starwheel Motor → Page 8-167.
???? If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
please rate my answer
i hope this helpfull
Posted on Dec 30, 2010
My HP printer shows error code 21.1.03, what does it mean?
This error indicates problem with the service station which is on the right end of the plotter. Open the window and have a look, the most common cause I run into is a piece of torn paper preventing the head from parking properly.
Apr 11, 2015 | HP Designjet T1100ps Printer
Grinding Noise
It would probably be time for a new hard drive. You can try putting it in a plastic back and them put it in the freezer for an hour. Sometimes this gives you enough time to pull the data off. A drive recovery service would be the other option if the information on the drive is very important to you (Ontrack.com or Driversavers.com)
Dec 17, 2013 | United Stationers HP Designjet T1100ps 44...
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Replace hp designjet t1100ps hard disk
Designjet T1100ps -Q6687A.
08:11 error. The formatter is okay but the hard disk is bad. How can I load the system software in a blank hard disk or try to clone
Apr 28, 2012 | HP Designjet T1100ps Printer
HP designjet 90 error code: 22.10
System Error: 22:10
Ink Supply Station failure.
Corrective Action: Replace the Ink Supply Station
(The Ink Supply Station is the mechanical part under the ink cartridges.)
Jun 13, 2011 | HP Designjet T1100ps Printer
Hi hp designjet t1100ps plotter showing error code 86:01, paper jam. but physically there is no paper or obstacle in print area. carriage block also moving one time right to left then the error code is...
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Apr 01, 2011 | HP Designjet T1100ps Printer
How to resolve eror code 47.01 hp designjet T1100
this error code is Starwheel Motor failure.
Feb 25, 2011 | HP Designjet T1100ps Printer
DEAR ERROR CODE 08:11 IN LCD MONITER MY PRINTER IS HP PLOTER T1100PS WHAT IS THE SOLUTION AND THANK FOR YOU AHMED
You have a possible 'formatter' problem.
No communication between the Front Panel and the Main board is the description.
Try switching the power OFF from the back of the printer and unplug the power cord.
Plug the cord back in and power up.
If the error persists, you are going to have to get a tech to look at it.
Jan 29, 2011 | HP Designjet T1100ps Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
The HP DesignJet T1100ps printer has a 79:04 error code. What kind of error is this and how can I solve this problem? please, help ! !
hp will never tell you but this error is a kind of a catch all error basically the service manual says to reload the firmware. check the file you are sending. i have seen a bad file cause this error. hope this helps.
Jun 09, 2009 | HP Designjet T1100ps Printer
HP Designjet T1100ps Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
