"not working" SimpleDrive 1TB Turbo
    Sergeant:
  • 320 Answers
Hi Mav, According to the specs at SimpleTech, the HDD is plug and play, so here is what I would try.
  • unplug the HDD
  • open the Device Manager
  • click on the + next to Hard Disks
  • select the drive
  • uninstall the driver
  • turn the computer off
  • reboot
  • turn it off again
  • plug in the HDD
  • reboot
Window should reinstall the HDD. If that does not work, I would then download CCleaner from Piriform, link is listed below. Once you have it installed, use the Registry Cleaner after uninstalling the HHD driver. Select "clean all" when prompted. Make sure that when CCleaner asks if you want to backup the Registry to select Yes, just in case something does go wrong you can restore the Registry to as it was before. I have used this program on many different systems and never had a problem. After cleaning, shut down and plug the HDD back in and reboot. By the way, CCleaner has some other great utilities that help keep your computer clean.
  • If this helps resolve your issue, would you please rate the solution. If this does not help, please leave a comment giving me more information on the problem and I will try to help you further.
Posted on Dec 30, 2010
Can't find simpletech on my computer - it was there, but it could not let me open it and would not shut off with the eject button to remove. Now my computer doesn't recognize it at all
You can try going in the add / remove and uninstalling the program, then go into devices and remove from there as well. Also go to the folder it is still listed in and find the uninstall there. Delete all those to your recycle bin. Reboot twice! Then on the 2nd reboot, plug the external in and make sure it has power and is turned on. See if it reappears again.
On another site, this next bit is what someone else tried (the last one), see if that works for you.
Storage forum Simpledrive 1TB External HDD Problem
Mar 25, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
Where can i purchase a power cable for my SimpleTech Pro Drive 1TB External?
You can use any 12V/2A tip positive power supply at Radio Shack, Best Buy, etc
Aug 01, 2011 | SimpleTech 1TB SimpleDrive Pro External...
Hallo. My simple drive hitachi 1TB 96300-41001-170 dont appear in my computer. I need driver but i cant fint it.
This should be plug-n-play. Have you tried restarting the computer with the hard drive plugged in? If that doesn't work, I would return it.
Apr 14, 2011 | SimpleTech 1TB SimpleDrive Pro Duo...
My external hard drive fell (simpledrive 1TB), he light comes on but my computers are not reading it.
had the same thing happen to me last year. does it still have a waranty on it. if it doesn't you can open it up hook it up to your computer directly get the stuff off it. not much else if the contacts are brocken you try to resoder them
Mar 22, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have a SimpleTech SimpleDrive 1TB just got it last month. I went to plug it in and light comes on but I can't find it under computer. How do I find it?
Are you trying to connect using USB or eSata. In either case try connecting the drive with the computer OFF. Boot, then look under MyComputer - Properties - Mangage - Disk Management to see if the drive is recognised.
Oct 29, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
The light is white..The computer doesn't seem to
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
You may want to skip the format section lower down
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Aug 25, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
General questions regarding simpletech simpledrive.
You probably have to initialize and/or format the drive.
Right click my computer and click Manage (assuming windows xp)
Go to disk management
See if you see the drive listed somewhere there. Should show approximately 950gb disk drive
If so right click that drive listed and choose either format, or create partition.
If you create the parttiion, make sure to click quick format, otherwise it will take a long time.
Hope this helps
Jul 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
