Remove the printer from the computer, delete from printers in control panel and re install. Should reset up network unless board is bad. Also in control panel find system, devisce manager and click on that. This will give a list all the devices in your computer. See is there are any yellow items with a question mark, Also check to see if the network device is there. If is not you may need a new network card. They do get taken out by surges. Network cards are not expensive....
Hi, every one My proplem in my Riso 3750 it is not work in speeds 3,4,5 he work only in speeds 1,2...
(More)
Hi, every one My proplem in my Riso 3750 it is not work in speeds 3,4,5 he work only in speeds 1,2 when I' use paper size A4R, A4 . But when I' use paper size A3 he work normal in all speeds
I have a Sharp ARM550N.This one has a paper tray error F3-12. Tray 1(paper tray desk trouble). I...
(More)
I have a Sharp ARM550N.This one has a paper tray error F3-12. Tray 1(paper tray desk trouble). I took the cover off of the front of tray 1 so I could watch the elevator. The one on the right side works fine, but the left one does not move up. I switched out the drive motor and gears from the right side to the left. It did not help. I then switched the small board that has the two sensors on it and that did not help. I took the gearbox apart and watched the worm gear and it would not even try to turn when I blocked the sensors. The right side did turn.Someone please help. I have spent 3 hours on this one.
My Kyocera 2050 will occasionally print duplex pages in the opposite order mid-job. If I have a 30...
(More)
My Kyocera 2050 will occasionally print duplex pages in the opposite order mid-job. If I have a 30 page file, send it to duplex, it will print the first few in the right order (1-2-3-4 etc) but then will do it backwards (4-3-2-1), or sometimes just randomly, so that all the pages are in the wrong order. Why on earth is it doing this?
