Question about Vacuums
I have a Janome SX2122 or SX2122R, this is my grandmother's machine originally and possibly from the 90s. I broke (bent) the needle today and replaced it with another on exactly the same, however, the machine now won't pick up the bottom thread (the one from the bobbin). Can anyone assist me with this? So far I have: - rethreaded the bobbin - pulled out the bobbin housing system and cleaned it - rethreaded everything i could think of rethreading. Your assistance with this is greatly appreciated - I am 6 inches from finishing the quilt I am making for my grandma.
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
SOURCE: Janome 6600 sewing machine. bobbin
Make sure you're using a polyester thread (I use maxilock serger thread) then a stretch needle, and hold the tails of your thread until you get started into the seam so the fabric cannot push down into the opening on the throat plate.
Also, a small zigzag stitch (about 1.8 - 2.0 wide) is good to use on lycra as that will allow the fabric to stretch after the garment is made.
This is stuff I've used with my 6500P and other previous Janome machines in making Ice Skating outfits.
Posted on Oct 26, 2010
  • 5603 Answers
SOURCE: Janome sewing machine Harmony 2139 The
A common problem is if needle is in backwards. The small groove side should be toward the operator. As the needle starts back up after going clear down, a small loop should form on the side of the needle away from teh operator. The shuttle has a point that goes through this loop to snag the upper thread and carry it over the top of the bobbin. Also verify that needle is propely seated.
If an accident has happened with the machine that MIGHT have disturbed the timing, then that could be the cause and one would have to take it for repair.
Slowly watch for the loop, with covers off, and manually cycle to watch for the operation I have described.
Posted on Dec 03, 2010
tunde007
  • 2382 Answers
SOURCE: When I start to sew
Hi, if your sewing machine thread is not properly threaded, the bobbin thread won't be pulled up into the fabric the way it needs to be. Occasionally the upper thread can catch on a moving part or get stuck, which impedes the easy flow of thread through the needle, creating a tangle. Unthreading your machine completely and rethreading it will correct this issue.
The bobbin must be placed properly into the bobbin case or it can unwind the wrong way. When this incorrect unwinding occurs, the bobbin's thread doesn't interact correctly with the upper thread. The knots it needs to make to form the stitches aren't made and the thread, instead of making knots, makes a giant, tangled mess underneath your sewing project. To make sure this doesn't happen, or to correct the problem if it does happen, place the bobbin in the case so that the thread unwinds in a counter-clockwise motion, with the thread being pulled from the left side of the bobbin to the right.
Changing your needle can also corrects this issue.
Posted on Feb 06, 2011
male_28_cam
  • 1555 Answers
SOURCE: i have a futura II
I don't know whether I shall provide you this solution or not but the repair manual for your machine is not available. It's available for a purchase specially for fixing bobbin tension.
In case you don't wish to buy it kindly ignore my solution and proceed for other experts solution. Here is the link from where you can buy.
http://www.tandtrepair.com/Futura.html
Bobbin Winder Adjustment Guide
4 pages of how to adjust the bobbin winder on the:
Futura 900 - 920 - 925; Athena 1200 - 2000; Creative Touch 1030 -
1036; Touch Tronic 2001 - 2005 - 2010
(Download Only)
$5.50
Posted on Mar 16, 2011
The needle of my sewing machine hits against metal on every fourth turn both forwards and backwards. If I push it, the needle breaks. What should I do?
One of the most common problems is a bent needle. But, if yours breaks, then maybe you aren't putting it up into the holder all the way. It really won't break the bobbin holder if it's made of metal. So, when you put your new needle in, make sure the flat side is facing the right way (another common mistake) by looking into your manual to check which way is correct. Then, when you are putting it into the holder, be sure the holding screw is as far out as it can be and wiggle the needle as you're sliding it up. Keep sliding and wiggling until you can't slide and wiggle any more. Then, hand tighten the screw and finish tightening it with a screw driver. That should do it. Also, make sure you are using the correct needle for your machine. There are many different type, but not all fit every machine. Good luck!
Feb 12, 2015 | SewShop.com Singer Model 4538 Instruction...
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
Why is my sewing machine skipping stitches
If the needle is slightly bent it won't pick up the lower thread all the time. Try using a new needle.
Sep 26, 2012 | Singer 7256 Fashion Mate Sewing Machine
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
How do i time m sewing machine. janome 2049. it's not grabbing the string from the bottom
It may not be a timing problem. First step is checking your needle. Is it the correct one? Is it inserted all the way with the eye faced properly? Is the eye large enough for the thread? (Thread must pass freely) And finely, is the threading correct? Double check these things first, timing can get a little involved.
Aug 19, 2011 | Vacuums
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
I think I just answered this question. But if not, try to set the tension adjustment and or the type of stitch. Let me know if this works or not.
Dec 02, 2010 | Vacuums
Janome 6600 sewing machine. bobbin thread is gumming up underneath on a swimsuit knit type material (4 layers). Brand new machine had 1 1/2 weeks. Sometimes material goes down into the bobbin area jammed...
Oct 17, 2010 | Vacuums
Hi I'm Sharon .I just dropped the pedal of a Janome sewing machine and now it doesn't work. Can i get a repair close to inner city Sydney? Ta
hi sharon the quickest easiest way for you would be to go to this page and contact jerome australia directly to assist you. http://www.janome.com.au/contact_janome.php
i may add that if you explain what happened and how much you lke their sewing machines they may possible send you one as a goodwill gesture (some companies still do that tho don't ask them directly)
as a side note my aussie wife uses the expression 'ta"... love it
Sep 28, 2010 | Vacuums
Vacuums Logo
217 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
