Question about Toro Snow Blower Scraper For S200 s620 New 233170 ()
I have a Toro S620 snow blower, I push the primer bulb and it starts right up then dies. If I keep pushing the primer bulb continualy it will keep running but the moment I quit it dies.
    President:
  • 1,033 Answers
The carburetor bowl needs to be taken off and most likely the float and needle need replacing. When you prime the carb, this is shooting gas straight to the carb instead of traveling though the jets. This is a very easy task, but I know if you're using a snow blower you need it quick. The kit is about $5 and be sure to take your machines info with you.
Posted on Dec 30, 2010
How do i change the primer bulb on a toro model #ccr2450 snow blower
most primer bulbs are held in place by a metal ring plate with either 2 or 4 screws
remove the plate and the bulb will fall out
make sure that the molded edge of the new bulb is correctly fitted into the groove in the body and refit the plate and screws
Sep 06, 2015 | Toro Ccr Snowblower
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
My toro s620 will not start I replaced the spark plug still nothing won't even say anything
Well, There is nothing like a good repair shop to take care of a problem. I would recommend looking at the diagrams at a site like www.arcolawn.com and consider the carburetor rebuild kit fuel line and the primer. Inspect the parts on the machine and order replacments right at the web site.
Good luck
please vote my fix up if you find it helpful
Joe
Feb 03, 2011 | Toro Snow Blower Scraper For S200 s620 New...
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How to instal primer plunger on Toro Snow blower 1000E
The new primer bulb should have come with a plastic retaining ring. If you have the new ring then pull the old ring and primer bulb out with long nose pliers.
Then you insert the new rubber bulb until the outer part of the bulb face mates with the carb face. Then install the ring press both pieces into place until it is just below flush.
(If the new bulb did not come with a new plastic ring... you are going to have to ever so gently coax the old ring out with your fingers crossed hoping it does not break.) I have personally broken more than 50% of the old rings... trying to get them out.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Toro Lawn Mower With Toro Power Tools
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawm mower
the bulb is allowing air in some where. Replace it.
Jul 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Snow Blower Scraper For S200 s620 New 233170 () Logo
1,275 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
