Question about Abit BG7E Motherboard
My PC with an ABIT motherboard makes a cont beeps although my speakers are off. The beeps stops sometime and then start again. Do you have an idea what should I do. Regards Doron
  • Abit Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 30, 2010
Have an computer with ABIT AA8 motherboard When
Try to unplug and plug again the video card. As you describe it is a VGA card error.
Jan 20, 2011 | Abit AA8-DURAMAX Motherboard
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is on.at this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
Hey guys would you be so kind to try to help me out? a friend brought me a pc with an abit IS7 motherboard it can't boot instead, all fans start working then a red light, 3 short peeps and it stops. What...
The beeps might indicate the problem with RAM. Try plugging out the RAM modules and insert them back in one by one in different slots and then check.
Jul 17, 2009 | Abit IS7 Motherboard
Abit beep codes?
Here is a good discussion on the ABIT Beep codes. See if this helps you.
http://www.ocforums.com/showthread.php?t=218664
Good Luck,
Paul
Apr 17, 2009 | Abit AV8 Motherboard
Abit st6 raid motherboard just beeps . doesn't boot BIOS
hello
the beeps comes from motherboard are due to ram which is not properly inserted
so try to remove ram while pc is off and insert ram again
Nov 21, 2008 | Abit ST6 Motherboard
ABIT IP35V, LONG and Continues Beep when There is a Geforce GT8800 video card installed.
Beep by motherboard are due to hardware problems. It's either the hardware is problem or it's not properly connected. Try check your RAM or graphic card weather it is fix properly. And also try to check your jumper connector. Sometimes one of the jumper connector may be damage and create the beep sound.
Sep 20, 2008 | Abit Computers & Internet
MoBo speaker beeps while using computer
go into your bios and disable any kind of alarms related to your cpu or fans. hope this solves your problem.
Sep 20, 2007 | Abit IC7-G Motherboard
Abit BG7E Motherboard Logo
42 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
