Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
Kitchenaid dishwasher mdl: kud101t jbt0
Will not start. cycle lights come on but washer will not start when button is engaged.
Thank You,
Jack Goodman
  • 1 more comment
  • glassfixer Jul 19, 2008
    I have a Kitchenaid Model# KUDI01TJWH0. All the lights will light, but when you push the start button it will not start. Thank you for any help you can give. Thanks Kirk
  • RIC-RAC Mar 03, 2009
    I have a kitchenaid dishwasher KUDI01TJWH0 and when I press the start button, nothing happens (all other buttons appear to work normally) and yes, the start button "clicks" normally (it is not stuck). I found that by rapidly pressing the "heavy wash"and "start" button simultaneously will adventually start d/w. After which I just select the "normal" wash cycle. I am guessing that it must be the consul/control panel, but am not convinced that it is not the "brains" the microprocessor. Any help would be appreciated.
  • Anonymous Mar 13, 2014
    kitchenaid kudi24se start button does not engage but other buttons light up
  • 25 Answers
Try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
Posted on Jan 24, 2009
KitchenAid dishwasher KUDM01TJBS0 does not start.
Most likely your keypad is bad. Will need to replace the console.
Nov 20, 2011 | KitchenAid Dishwashers
KitchenAid KUDI10FL dishwasher- The door spring system broke and I repaired it, but now all of the sudden the dishwasher will not start. The door may have been dropped a couple of time before the spring...
Hi- It is possible that the door latch is not completely engaging. If the door dropped the hinges may have bent a little thus preventing a good contact with door switch. Try pressing and holding the door shut, hard, and pressing start. If that works then replace the latch assembly. It is also possible the membrane switch got rattled with the door falling, or a wire is grounding out somewhere. Hopefully it is just the latch. Hope this helps, good luck.
Sep 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwashwer won't start and can't reset to restart
Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
Apr 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 07, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
1,188 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
